[Mapserver-users] Compile error
Nicolas Boretos
nicolas at maich.gr
Thu Jun 17 02:17:41 EDT 2004
Kralidis,Tom [Burlington] wrote:
>Hi,
>I'm running into issues in deploying MapServer.
>Info:
>- OS: Fedora Core 2
>- supporting libs installed in default locations
>I've included my terminal session in trying to compile (attachement
>build_output.txt).
>Note that it's looking for the libpq lib. I even tried copying
>/usr/local/pgsql/lib/libpq* to /usr/local/lib, but ldd still gives me
>problems for libpq.
>Any suggestions are valued.
>Thanks
>..Tom
>Tom Kralidis
>Systems Scientist
>Environment Canada
>Tel: +01-905-336-4409
>http://www.ec.gc.ca/
Hi Tom,
I usually add the shared lib directory to the /etc/ld.so.conf file, and
then I do
an "ldconfig" in that directory, to update.
Some OS's e.g. Solaris sometime need explicit lib path, e.g.
LD_LIBRARY_PATH="path to libs...." : export LD_LIBRARY_PATH
regards,
nicolas boretos
