[Mapserver-users] Why Mapserver GML does not validate with XMLSpy
Paul Spencer
spencer at dmsolutions.ca
Thu Jun 17 16:00:07 EDT 2004
I just tried this. If I click the link (as it appears in my email
client), the & are automagically translated to &. Even when I copy
the link, they are replaced. If I revert the & to & in my browser's
address bar, it does not work (same error message that Bart reported).
This is on WinXP using mozilla ... and on linux using Mozilla too
One note: the link as written below will generate a ServiceException
because the first & is not escaped and so MapServer will read the fact
that it is the WFS service that is being invoked, and will generate a
ServiceException for an incomplete request. If the first & is encoded
as & then you get the mapserv error message.
HTH
Paul
Bart van den Eijnden wrote:
> Hi Daniel,
> what the XMLSpy people are saying is that using & in a URL to a CGI
> is valid.
> If I click on the link I do not get the schema back, I get a service
> exception report that the version is missing. Or if I use & instead
> of & even before the service=WFS name-value pair, I get the "mapserv():
> Web application error. No template provided." error. So mapserv CGI only
> interprets name value pairs if they are separated by & instead of &.
> Is this something Windows specific perhaps, you are probably on Linux
> when clicking the URL in a browser? XMLSpy is on Windows as well ofcourse.
> Best regards,
> Bart
> On Thu, 17 Jun 2004 14:23:53 -0400, Daniel Morissette
>>> Hi Daniel,
>>> the guys at Altova (XMLSpy) seem to have a different opinion on this
>>> subject, see:
>>> http://www.altova.com/forum/forums/forum.asp?forumid=28&page=1&select=4262#xx4262xx
>> Different opinion on what? They wrote that the ampersand needs to be
>> escaped in the instance document, which is exactly in line with what I
>> wrote. I also added that the client needs to unescape the string
>> *before* calling the server and they suggest that this is what is
>> being done:
>>> ...so this is the URL:
>>> http://www.vz.geodan.nl:1112/cgi-bin/mapserv.exe?map=/ms4w_20/apps/general/map/gemeentes.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Gemeentes
>>> ...being sent to the server. This is a perfectly valid construction:
>>> http://www.biglist.com/lists/xsl-list/archives/200104/msg01061.html
>>> ...that your CGI application or web server seems to be having
>>> problems handling correctly.
>> ... if I click on the URL above I see a XML schema as expected from a
>> DescribeFeatureType response. So what's the problem exactly? What does
>> he mean by "having problems handling correctly"?
>> Perhaps I missed something obvious at the beginning? Is it that the
>> schema that is returned is not valid?
>> Daniel
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
