[Mapserver-users] Using XMLSpy with GML
Bart van den Eijnden
bartvde at xs4all.nl
Fri Jun 18 03:48:58 EDT 2004
I used XMLSpy purely for validation of the GML, not for import.
You can however, use Frank Warmerdam's OGR library to import GML and save
it as another format (using the ogr2ogr utility). There is also a PHP
version of Frank's OGR library called php_ogr.
Without conversion, you can also use GML data directly in Mapserver
through an OGR connection, see:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0402/msg00570.html
php_ogr can be found here:
http://maptools.org/dl/php_ogr/
BTW: I don't know what you mean by OS GML (the OS part of it).
Best regards,
Bart
On Fri, 18 Jun 2004 05:42:29 +0800 (CST), guoloi dou
<douguoli at yahoo.com.cn> wrote:
> Hi, I am trying to implement a web application using MapServer, PHP in
> Windows with OS GML data. I saw your discussion about using XMLSpy to
> process GML. Is it possible to use XMLSpy import OS GML data or do you
> guy know any other ways?
> Thanks,
> Zhengda Lu
> Do You Yahoo!?
> å«é®ç®±å¤ªå°ï¼é
èçµé®èªå©æ©å®¹ï¼
