[Mapserver-users] Using XMLSpy with GML
Bart van den Eijnden
bartvde at xs4all.nl
Fri Jun 18 12:37:59 EDT 2004
I don't have a demo program handy for this, sorry. I would use the OGR
connection in Mapserver instead of php_ogr though, if your sole purpose is
viewing the data.
BTW: try responding to the whole list, you have a bigger chance of
somebody having a demo somewhere.
Try downloading OpenEV_FW, and run ogrinfo on your GML file. If this
works, you can use it in Mapserver.
See also:
http://gdal.maptools.org/ogr/drv_gml.html
http://mapserver.gis.umn.edu/doc42/ogr-howto.html
Hope this helps.
Best regards,
Bart
On Fri, 18 Jun 2004 20:36:43 +0800 (CST), guoloi dou
<douguoli at yahoo.com.cn> wrote:
> Hi,
> Thanks for your reply. OS in my letter actually means Ordnance Survey.
> As I am new to this whole system. Do you mind offering me a demo program
> how to use PHP_OGR and MapServer viewing the GML file.
> Tons of thanks and regards,
> Zhengda Lu
> Bart van den Eijnden <bartvde at xs4all.nl> wrote:Hi,
> I used XMLSpy purely for validation of the GML, not for import.
> You can however, use Frank Warmerdam's OGR library to import GML and save
> it as another format (using the ogr2ogr utility). There is also a PHP
> version of Frank's OGR library called php_ogr.
> Without conversion, you can also use GML data directly in Mapserver
> through an OGR connection, see:
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0402/msg00570.html
> php_ogr can be found here:
> http://maptools.org/dl/php_ogr/
> BTW: I don't know what you mean by OS GML (the OS part of it).
> Best regards,
> Bart
> On Fri, 18 Jun 2004 05:42:29 +0800 (CST), guoloi dou
> wrote:
>> Hi, I am trying to implement a web application using MapServer, PHP in
>> Windows with OS GML data. I saw your discussion about using XMLSpy to
>> process GML. Is it possible to use XMLSpy import OS GML data or do you
>> guy know any other ways?
>> Thanks,
>> Zhengda Lu
>> Do You Yahoo!?
>> çå²åç» åãç忥紵éå°æª¸é¢ç¸åé·ï¿½å§ªéµâ�é?lt;br>
