[Mapserver-users] PHP: was dynamic point drawn?
Eric Bridger
eric at gomoos.org
Fri Jun 18 20:39:01 EDT 2004
At 03:58 PM 06/18/2004 -0700, Hal Mueller wrote:
>I'm generating a set of dynamic points from a mySQL database, based on attributes of the points. Then I plot that set of points.
>If I'm plotting on a regional map, I'd like to know which of the (worldwide) points were actually drawn. Is there a function to do that? Something like
>$map->testInExtent($layer, $point)
>To be more specific, my question in the code is "which of these moving objects are in the map that I just drew?".
>I could look at the extent of the map manually, project the point, and test that--but it seems like there must be a canned way to do this already.
Not really a "canned" way but a brute force way. (Mapserver will take care of projection stuff for you)
I have done something similiar by using the $shape->contains($point) method. I did this with polygon shapes not rectangles but it should work the same.
1) create a shape by from you $map current extent: $rect = $map->{extent}
2) Create a shape from that $rect, Perhaps with $shape->{bounds} = $rect; Or create the proper lines and use $shape->add($line). (This is what I did). see create_rect() perl code below.
3) loop thru your points and call $shape->contains($shape).
foreach my $point ( @points) {
# Does the shape contain the point?
my $ret = $shape->contains($point);
if($ret == 1){ # yes
push @points_found, $point;
This perl routine creates 10minute squares based on a passed in centroid.
sub create_rect{
my($lat, $lon) = @_;
my $point = new mapscript::pointObj();
my $line = new mapscript::lineObj();
# max xy point
$point->{x} = $lon + .0833;
$point->{y} = $lat + .0833;
$line->add($point);
# max x min y
$point->{y} = $lat - .0833;
$line->add($point);
# min xy
$point->{x} = $lon - .0833;
$line->add($point);
# min x max y
$line->add($point);
# max xy point again to close polygon
$line->add($point);
my $shp = new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON);
$shp->add($line);
$shp->setBounds();
return $shp;
Eric Bridger
