[Mapserver-users] Ogr binaries
Bart van den Eijnden
bartvde at xs4all.nl
Sat Jun 19 07:30:46 EDT 2004
I just checked with my OpenEV version, and I have the same problem, the
ogrtindex seems to be compiled against an earlier GDAL/OGR version. The
binary date is also from 2002, so that seems to be the problem.
Frank, can you comment on this one?
Best regards,
Bart
On Sat, 19 Jun 2004 10:16:34 +0200, Gheysen Thibaut <gheysen.t at skynet.be>
wrote:
> Hi,
> I have try it but I always have the error that "gdal11.dll" can't be
> found.
> I use OpenEv 1.7.4. and the version of gdall.dll include is "gdal12.dll".
> Best regards,
> Thibaut
> ----- Original Message -----
> From: "Bart van den Eijnden" <bartvde at xs4all.nl>
> To: <gheysen.t at skynet.be>; <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, June 18, 2004 11:02 AM
> Subject: Re: [Mapserver-users] Ogr binaries
>> Hi,
>> just run the ogrtindex command from the OpenEV_FW\bin directory.
>> Don't copy the ogrtindex.exe to the directory where mapserv.exe is
>> situated (I assume that is what you are doing).
>> Best regards,
>> Bart
>> On Fri, 18 Jun 2004 10:36:09 +0200, <gheysen.t at skynet.be> wrote:
>> > Hello,
>> > Somebody can send to me a window version of the utility ogrtindex
>> > because this include in openEV need a other version of \"gdal.dll\"
>> that
>> > this include in the package.
>> > Thanks in advance.
>> > Gheysen Thibaut.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
