[Mapserver-users] reprojection, expressions, and query blues
Gustavo Alcides Concheiro Perez
gacp at d-konstruktors.org
Sat Jun 19 14:07:59 EDT 2004
Newbie questions, I expect:
1. I'm trying to reproject some shapefiles. I set the projection for the
layers (lat/long) and the (different) projection for the map (like LAEA---I
tried several) AFAIK the proj codes are correct, and I copied the tutorials
code as models. NOTHING HAPPENS. Layers are *not* reprojected but shown in
lat/long, and no error message pops anywhere, even when I use "DEBUG ON" on
layers. I'm totally baffled.
2. Same thing with passing a expression in the URL. Nothing happens; no error
message either.
3. I want the elevation for the query point. This is very important. I have
the DEMs (several), but I see no way to query a raster file with MapServer.
4. Is there a way to link tolerance (for mouseclicks on queries) to mapa units
(e.g. 10 km radius) instead of just pixels?
I'm using version 4.2. as CGI.
5. Finally, is there any tutorial that explains *concepts* and *strategies* on
how to do this, the *rationale* of it, and not just keyword references for
the code and map examples with pieces of code? I must confess that after
quite a bit of RTFM, I still can't really understand how to use MapServer.
TIA.
-gustavo
Gustavo Alcides Concheiro Pérez <gacp at d-konstruktors.org>
Unión de la Cruz del Sur
«Non serviam»
Clave pública GPG para gacp / GPG public key for gacp:
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.0.7 (GNU/Linux)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=AuyO
-----END PGP PUBLIC KEY BLOCK-----
