[Mapserver-users] sld example
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Mon Jun 21 08:44:57 EDT 2004
> -----Original Message-----
> From: Jean-Denis Giguere [mailto:jdenisgiguere at fastmail.fm]
> Sent: Monday, June 21, 2004 8:36 AM
> To: mapserver-users at lists.gis.umn.edu
> Cc: Kralidis,Tom [Burlington]
> Subject: Re: [Mapserver-users] sld example
> >>From: mapserver-users-admin at lists.gis.umn.edu
> >>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> >>Dean Gadoury
> >>Sent: Friday, June 18, 2004 10:42 AM
> >>To: MapServer List
> >>Subject: [Mapserver-users] sld example
> >>Hi,
> >>Does anyone have an example of an SLD document in which
> point symbols
> >>are styled?
> >>Dean
> > Try:
> > http://cgdi-dev.geoconnections.org/prototypes/sld/gcdb.xml
> In your example uses the tag <ExternalURL> which doesn't exist in
> version 1.0.0 of SLD. Do you have an example of SLD working
> in MapServer
> using <ExternalGraphic></ExternalGraphic> and <OnlineResource/> ?
Whoops!! I provided the wrong filename suffix -- try this:
http://cgdi-dev.geoconnections.org/prototypes/sld/gcdb.sld
..Tom
> Thank you in advance,
> Jean-Denis
> > Alternatively, you can also do this with PHP to convert existing
> > MapServer classes to OGC:SLD, i.e.:
> > <?php
> > // load mapscript
> > dl("php_mapscript_42.dll");
> > // instantiate a new Map Object
> > // with the mapfile as an argument
> > $oMap = ms_newMapObj("demo.map");
> > // generate an SLD into a string variable
> > $sldString = $oMap->generatesld();
> > // print out the SLD
> > // or do whatever with it
> > echo $sldString;
> > ..Tom
> > Tom Kralidis
> > Systems Scientist
> > Environment Canada
> > Tel: +01-905-336-4409
> > http://www.ec.gc.ca/
> >>___________________________
> >>Dean Gadoury
> >>DM Solutions Group
> >>30 Rosemount Ave. Suite 200
> >>Ottawa, Ontario. K1Y 1P4
> >>613.565.5056 ext. 24
> >>dgadoury at dmsolutions.ca
> >>www.dmsolutions.ca
> >>_______________________________________________
> >>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
