[Mapserver-users] MapServer Windows external symbol problem
Howard Butler
hobu at iastate.edu
Mon Jun 21 15:53:26 EDT 2004
Ed,
Under CVS MapServer, regex.obj is no longer available as a target. Also, I
was only building the regex.obj from GNU's regex and none of the test
harness. I later found a link to a message from Assefa that said he uses
PHP's regex. I rolled PHP into the mix and my regex problem went away.
Howard
At 02:49 PM 6/21/2004, Ed McNierney wrote:
>Howard -
>Add the target name "regex.obj" to the nmake command line - the errors
>come from trying to build the test applications, which you don't need.
>If you click on the first entry found by the Google search you emailed
>below, you'll find me saying the same thing <g>.
> - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com
>-----Original Message-----
>From: mapserver-users-admin at lists.gis.umn.edu
>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Howard
>Butler
>Sent: Monday, June 21, 2004 3:17 PM
>To: assefa at dmsolutions.ca
>Cc: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] MapServer Windows external symbol problem
>Assefa,
>I am trying to compile Windows MapServer, but I am having trouble
>getting regex to behave when it comes time to link. Apparently, many
>others have had trouble as well
><http://www.google.com/search?q=regex.obj+:+error+LNK2001:+unresolved+ex
>ternal+symbol+_printchar&hl=en&lr=&ie=UTF-8&c2coff=1&start=10&sa=N&filte
>r=0>.
>Here is the link error:
>regex.obj : error LNK2001: unresolved external symbol _printchar
>I have tried every permutation of putting that symbol in the header,
>making sure it is extern'ed properly (in both the C file and the
>header), but I am having no luck. I grepped through my VC++ include
>files and my cygwin include files for that function prototype
>(printchar), but I cannot find it anywhere.
>If you have any ideas of other things I might try, I'd greatly
>appreciate it.
>Thanks
>Howard
>Howard Butler
>Department of Statistics
>Center for Survey Statistics and Methodology Iowa State University
>212 Snedecor Hall
>Ames, IA 50011
>http://hobu.biz
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
