[Mapserver-users] How to log requests on remote wms-servers
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Jun 22 08:38:35 EDT 2004
Frieso ter Haseborg wrote:
> Hi,
> LOG "c:\Programme\Apache Group\Apache2\htdocs\tmp\ms.log"
> or
> LOG ms.log
> gives no difference. So far I never had any problems using '/' instead of '\'.
> Are there any other requirements to be met for ms to get a debug-log?
The LOG directive applies only to the mapserv CGI via the traditional
CGI interface. It has no effect with the WMS or WFS interfaces or with
MapScript.
BTW, there are two other ways to generate log output in MapServer:
- Setting the MS_ERRORFILE environment variable will log all error
messages to the specified file
- Compiling with --enable-debug (i.e. adding the -DENABLE_STDERR_DEBUG
-DNEED_NONBLOCKING_STDERR compile flags) will generate lots of debug
output to stderr (i.e. to the Apache error_log).
We've been talking about unifying all this, you'll find more details in
bug 709:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=709
Now, if all you need is to log requests then none of the above will do
what you want. In this case you could simply create a wrapper script
that logs the request and passes control to the mapserv.exe.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
