[Mapserver-users] Re: problemas within GDAL
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Tue Jun 22 09:17:10 EDT 2004
hello,
I'd like to add some tips on Frank's comments:
- a way to avoid this problem could be add you gdal dlls path to %PATH
variable of Windows XP/2000 ( My Computer->Advanced->Env.Variables).
this is the way I found to install diferent version of MapServer CGI and
PHPMapScript at the same win machine.
best.
http://www.consultoria.eti.br
UIN: 303747254
Treinamento em UMN MapServer - http://www.consultoria.eti.br/ptbr/?menuoption=mapserver
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
***Fim da Mensagem / End of Message ***
Frank Warmerdam escreveu:
> Eduardo Patto Kanegae wrote:
>> Hi Frank, ( sorry the long mail)
>> I downloaded GDAL 1.2 for Windows ( binaries)
>> but when trying to run any of the GDAL tools ( gdal_translate.exe,
>> gdalinfo.exe , gdalwarp.exe , gdalwarpsimple.exe, ogr2ogr.exe,
>> ogrinfo.exe ) I got the error:
>> "This application could not be loaded because the file
>> xerces-c_2_3_0.dll was not found..."
>> A few days ago you told me to download and use OpenEV-FW 174 which
>> contains all lastest binaries.
>> So I did it at the path C:\OpenEV_FW, but when starting it (
>> openev.bat )
>> I got the error:(i'll try translate the message to english ;-)
>> "It was not possible to find the entry point of
>> GDALGeneralCmdLineProcessor procedure at the dinamic library gdal12.dll"
>> another strange thing: I have MapServer 4.2 ( with PHPMapScript)
>> which I downloaded from MapTools.org, and if I overwrite my
>> c:\windows\system32\gdal12.dll ( which came with mapserver) with
>> gdal12.dll of OpenEV-FW174, then MapServer crashes.
> Eduardo,
> It drives me crazy that any applications dump their GDAL DLL's into
> c:\windows\system32. That is causing the problem. I would encourage
> you to try putting gdal12.dll somewhere else, like in the same cgi-bin
> directory that the mapserv.exe is. Putting it in the system32
> directory is just going to cause no end of compatibility issues.
> There are many versions of GDAL12.DLL that conflict. They need to
> be kept seperate.
>> So I tried to look for gdal1.1.9 bins but got no connection to
>> ftp.remotesensing.org
>> Then I installed OpenEV 1.7.0 for windows and OK. It has gdalinfo
>> working and that's what I was looking for.
>> but when openning openev I got:
>> "Impossible to find the entry point OGRSetGenerate_DB2_V72_BYTE_ORDER
>> at gdal11.dll"
>> ps.: I'm running Windows XP Home portuguese.
>> sorry sending this mail directly to you but I tried to subscribe at
>> http://remotesensing.org/mailman/listinfo/gdal-dev/ GDAL list but
>> browser is not reaching the page.
> Remotesensing.org is moving to a new machine, which is why there is so
> much chaos for all resources from there.
> Best regards,
