[Mapserver-users] OGR ovf access problem
COUTUJF at dfo-mpo.gc.ca
Tue Jun 22 14:37:31 EDT 2004
Hey Chip,
thanks for the hint, but I do have the latest Mapserver
installed (4.2 beta). The only thing is I think that 4.2 beta still uses
GDAL 1.1.x, OpenEV currently uses GDAL 1.2.
I'm not sure if ovf files are only supported in 1.2. I think it should work
with 1.1 hence my version should be OK.
Anymore ideas?
Thanks,
JF
-----Message d'origine-----
De : Chip Hankley [mailto:Chip.Hankley at rmtinc.com]
Envoyé : 22 juin 2004 13:56
À : COUTUJF at dfo-mpo.gc.ca; mapserver-users at lists.gis.umn.edu
Objet : Re: [Mapserver-users] OGR ovf access problem
First, make sure that you are using the LATEST version of MapServer. This
only works w/ MapServer versions compile with newer versions of GDAL. If you
are using one of the pre-compliled binaries, then it's very likely you're
version is NOT recent enough. As of last week, I found that the only version
that would do this was the 4.2 beta version mapserver binary on DM Solutions
website.
My hunch is that if the ogrinfo tests worked OK, then it's probably that
your MS version doesn't have the right version of GDAL.
Chip
>>> <COUTUJF at dfo-mpo.gc.ca> 06/22/04 12:26PM >>>
Hello list,
I'm trying to access a distant Oracle database from Mapserver using
the ovf file and an ODBC connection. I tested the ovf file with ogrinfo as
per the WIKI and it worked OK.
When I try to access the layer in mapserver I keep getting the following
error message:
msDrawMap(): Image handling error. Failed to draw layer named 'sipa'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `sipa.ovf'. File
not found or unsupported format.
I did try to follow WIKI tip #1:
1.Enable mod_env
2.add lines like: setenv ORACLE_HOME /path/
3.restart apache
But I don't have Oracle installed on the webserver's machine, only the ODBC
driver. So I can't figure out what the path should be...
Must I install Oracle?
Thanks,
JF
Jean-Francois Coutu
Canadian Coast Guard
coutujf at dfo-mpo.gc.ca
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Outgoing messages, along with any attachments, are scanned for viruses at
RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient. Any review or distribution by
others is strictly prohibited. If you are not the intended recipient,
please contact the sender immediately and delete all copies.
