[Mapserver-users] problem adding north arrow to map
Mark Adams
markadams at cuestasys.com
Wed Jun 23 09:12:03 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0005_01C45902.26C1FAB0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi all,
=20
I=92m hoping someone can point out what might be going wrong here.
Following the instructions in the wiki, I am trying to add a north arrow
to may map. I=92ve got a basic north arrow image (northarrow1.gif), =
I=92ve
added a pixmap symbol referencing it, and I=92ve added a layer to the =
map.
However, the GIF never shows. I=92ve tried this in both a mapscript app
and the basic Itasca demo, same result. I know there is nothing wrong
with the GIF or symbol definition, as it shows fine if I use this symbol
on a =93regular=94 layer rather than a feature layer. Any ideas? Have I
defined the feature layer wrongly? Here are my symbol def and layer def:
=20
SYMBOL #North Arrow
NAME "northarrow1"
TYPE pixmap
IMAGE "northarrow1.gif"
END
=20
LAYER
NAME "North Arrow"
STATUS DEFAULT
TRANSFORM FALSE
TYPE POINT
FEATURE
POINTS 250 250 END
END
CLASS
SYMBOL 'northarrow1'
END
END
=20
Thanks in advance.
Mark Adams
Business & Systems Analyst
Cuesta Systems Inc.
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: markadams at cuestasys.com
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C45902.25B48250">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PostalCode"/>
<o:SmartTagType =
name=3D"State"/>
<o:SmartTagType =
name=3D"City"/>
<o:SmartTagType =
name=3D"Street"/>
<o:SmartTagType =
name=3D"address"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi all,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I’m hoping someone can point out what might be =
going
wrong here. Following the instructions in the <span =
class=3DSpellE>wiki</span>, I
am trying to add a north arrow to may map. I’ve got a basic north =
arrow image
(northarrow1.gif), I’ve added a <span class=3DSpellE>pixmap</span> =
symbol
referencing it, and I’ve added a layer to the map. However, the =
GIF never
shows. I’ve tried this in both a <span =
class=3DSpellE>mapscript</span> app
and the basic </span></font><st1:place><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Itasca</span></font></st1:pl=
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> demo, same
result. I know there is nothing wrong with the GIF or symbol definition, =
as it
shows fine if I use this symbol on a “regular” layer rather =
than a
feature layer. <span class=3DGramE>Any ideas?</span> Have I defined the =
feature
layer wrongly? Here are my symbol def and layer =
def:<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0 </span>SYMBOL =
#North Arrow<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0=A0=A0 =
</span>NAME
"northarrow1"<o:p></o:p></span></font></p>
</span>TYPE <span
class=3DSpellE>pixmap</span><o:p></o:p></span></font></p>
</span>IMAGE
"northarrow1.gif"<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'>=A0 =
</span>END<o:p></o:p></span></font></p>
</span>LAYER<o:p></o:p></span></font></p>
font-family:Arial'><span =
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0 </span>NAME
"North Arrow"<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0 </span>STATUS =
DEFAULT<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0 </span>TRANSFORM
FALSE<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0 </span>TYPE =
POINT<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0 =
</span>FEATURE<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0=A0=A0 </span>POINTS 250 =
<span
class=3DSpellE>250</span> END<o:p></o:p></span></font></p>
</span>CLASS<o:p></o:p></span></font></p>
style=3D'mso-spacerun:yes'>=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0=A0 =
</span>SYMBOL
'northarrow1'<o:p></o:p></span></font></p>
font-family:Arial'>Thanks in advance.<o:p></o:p></span></font></p>
<p class=3DMsoAutoSig><font size=3D3 color=3Dnavy face=3D"Times New =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>------------------=
------------</span></font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Mark =
Adams</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Business & =
Systems
Analyst</span></font><span =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Cuesta Systems =
Inc.</span></font><span
<p class=3DMsoAutoSig><st1:Street><st1:address><font size=3D3 =
color=3Dnavy
face=3D"Times New Roman"><span =
yes'>5230 South Service =
Road</span></font></st1:address></st1:Street><span
<p class=3DMsoAutoSig><st1:place><st1:City><font size=3D3 color=3Dnavy
yes'>Burlington</span></font></st1:City><font color=3Dnavy><span
style=3D'color:navy;mso-no-proof:yes'>, </span></font><st1:State><font
color=3Dnavy><span =
style=3D'color:navy;mso-no-proof:yes'>ON</span></font></st1:State><font
color=3Dnavy><span style=3D'color:navy;mso-no-proof:yes'> =
</span></font><st1:PostalCode><font
color=3Dnavy><span style=3D'color:navy;mso-no-proof:yes'>L7L =
5K2</span></font></st1:PostalCode></st1:place><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Phone: =
905-333-4544 x14</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Fax: =
905-333-0455</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Email:
markadams at cuestasys.com</span></font><span =
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0005_01C45902.26C1FAB0--
