[Mapserver-users] problem adding north arrow to map
Mark Adams
markadams at cuestasys.com
Wed Jun 23 11:00:24 EDT 2004
Excellent! That did the trick - as it turns out it was the empty STYLE
object that was needed, the other changes didn't matter. But can you
tell me why this empty STYLE object was needed?
Mark Adams
Business & Systems Analyst
Cuesta Systems Inc.
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: markadams at cuestasys.com
-----Original Message-----
From: Charlton Purvis [mailto:cpurvis at asg.sc.edu]
Sent: Wednesday, June 23, 2004 10:45 AM
To: markadams at cuestasys.com; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] problem adding north arrow to map
Could you try adding
POSTLABELCACHE TRUE
and perhaps an empty STYLE object?
BTW, I use TRANSFORM OFF instead of TRANSFORM FALSE (don't remember
why!).
So something like:
> > LAYER
> > NAME "North Arrow"
> > STATUS DEFAULT
> > TRANSFORM OFF
POSTLABELCACHE TRUE
> > TYPE POINT
> > FEATURE
> > POINTS 250 250 END
> > END
> > CLASS
> > SYMBOL 'northarrow1'
STYLE END
> > END
> > END
> From: Mark Adams [mailto:markadams at cuestasys.com]
> Sent: Wednesday, June 23, 2004 10:11 AM
> To: mapserver-users at lists.gis.umn.edu
> I've tried having the symbol in a symbol file, as well as in the map
> file; same result. Executing mapserv -v indicates support for GIF
output
> (I'm using the standard windows binary PHP mapscript 4.2 package), and
> as I said I've had success displaying the symbol with regular layers,
> but not with this feature layer. I do have it as the last layer in the
> map file. I've tried removing all other layers from the map file
except
> the north arrow feature layer, it still doesn't show.
> For what it's worth, here's a further oddity. The layer shows in my
HTML
> legend if I set status to ON - that is to say the layer *name* shows
in
> the legend, but not the symbol. Again, if I use this symbol in a
> different layer (I used it on a line layer for example), it displays
on
> the map, and in the legend.
> Mark Adams
> Cuesta Systems Inc.
> Fax: 905-333-0455
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Wednesday, June 23, 2004 9:51 AM
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] problem adding north arrow to map
> The symbol probably should be in the symbol.sym file
> Is this the last layer in the mapfile? if not try putting it last so
it
> gets drawn on top of the other layers.
> Remember that 0,0 is upper left when TRANSFORM FALSE is set so the
> symbol should be placed 250 to the right and 250 down from the top.
> -Steve W.
> Mark Adams wrote:
> > Hi all,
> > I'm hoping someone can point out what might be going wrong here.
> > Following the instructions in the wiki, I am trying to add a north
> arrow
> > to may map. I've got a basic north arrow image (northarrow1.gif),
I've
> > added a pixmap symbol referencing it, and I've added a layer to the
> map.
> > However, the GIF never shows. I've tried this in both a mapscript
app
> > and the basic Itasca demo, same result. I know there is nothing
wrong
> > with the GIF or symbol definition, as it shows fine if I use this
> symbol
> > on a "regular" layer rather than a feature layer. Any ideas? Have I
> > defined the feature layer wrongly? Here are my symbol def and layer
> def:
> > SYMBOL #North Arrow
> > NAME "northarrow1"
> > TYPE pixmap
> > IMAGE "northarrow1.gif"
> > END
> > LAYER
> > NAME "North Arrow"
> > STATUS DEFAULT
> > TRANSFORM FALSE
> > TYPE POINT
> > FEATURE
> > POINTS 250 250 END
> > END
> > CLASS
> > END
> > END
> > Thanks in advance.
> > Mark Adams
> > Cuesta Systems Inc.
> > Fax: 905-333-0455
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
