[Mapserver-users] Changing scale in query map
Tyler Mitchell
tjmitchell at riverside.bc.ca
Wed Jun 23 11:56:03 EDT 2004
Maria, are you using a demo application to start with or did you start
from scratch? I don't know the answer for you but maybe if you provide
some more info to the list it will help. I've also changed the subject
line to be a bit more descriptive :)
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 06/22/2004 04:11:00 AM:
> Hi again!
> I sent a message few days ago but I have not received any answer.
> Please, Should you find a solution for my problem? Thanks again
> scale in query result
> I need to show the query map in the same scale as the map
> in the map template, but I want the size of querymap smaller than the
map.
> If I show the query result in the same page (target = _self) it
> goes, but if I show
> the query result in a different window the query map has got the
> same extent than the map, so
> the resultant scale is bigger. (I need to do that in a new window)
> How can i do that?
> Thanks in advanced. Maria.
> // query result in a new window
> function CheckTarget(){
> if (document.mapserv.mode.value == "query"){
> document.mapserv.target="query";
> window.open('', 'query', 'resizable=yes,scrollbars=yes,toolbar=no,
> menubar=no,width=400,height=300');
> } else {
> document.mapserv.target="_self";
> // querymap in mapfile
> QUERYMAP
> SIZE 300 187
> STATUS ON
> STYLE HILITE
> COLOR 0 255 255
> END
> Adeu. Maria.
> Juan acaba de ganar 40 euros vendiendo un jersey que no usaba
> gracias a Ebay, ¿cuanto quieres ganar tú?
> http://ad.doubleclick.net/clk;7342022;7829128;i?http://adfarm.
> mediaplex.com/ad/ck/1185-18912-4660-5?
> RedirectEnterâner=36993&loc=http://www.es.ebay.com
> _______________________________________________ Mapserver-users
> mailing list Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.
> edu/mailman/listinfo/mapserver-users
