[Mapserver-users] Perl/Mapscript scalebar problem
Eric Bridger
eric at gomoos.org
Fri Jun 25 15:57:55 EDT 2004
On Fri, 2004-06-25 at 15:36, Stephen Woodbridge wrote:
> Hi all,
> I have a mapfile that works great in cgi mode and shows an embed
> scalebar as defined in the mapfile.
> When I use this same mapfile in a with Perl/mapscript the scalebar does
> not display!
> Is there something I have to do in mapscript to get the embedded
> scalebar to show up on the map?
Hi Stephen,
You have to do:
# embed scale bar in map img
my $scale_img = $map->drawScalebar();
$map->embedScalebar($scale_img);
You have to do either:
my $img = $map->prepareImage();
or
$img = $map->draw();
first.
Eric
