[Mapserver-users] Query results highlighting
Mark Adams
markadams at cuestasys.com
Fri Jun 25 17:22:42 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0011_01C45AD9.05EC6CC0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi folks,
=20
Quick question from a newbie: is there a way to change the
size/intensity of the highlighting of query results? In my map file =
I=92ve
defined a Querymap layer, set to hilite in a bright yellow colour, but
I=92ve noticed that for polygons layers where I=92ve only defined an
Outlinecolor and no fill color, only a narrow outline gets highlighted,
not the feature itself. As a result you have to squint at the screen to
determine what features are actually =93highlighted=94. I could change =
my
map file so that all polygon layers are filled, but this seems extreme.
Is there an other way to highlight the whole feature, or change the
highlight outline to a thicker line?
=20
Thanks.
=20
Mark Adams
Business & Systems Analyst
Cuesta Systems Inc.
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: markadams at cuestasys.com
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C45AD9.058D0EB0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi folks,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>Quick question from a newbie: is there a way to =
change the
I’ve defined
a <span class=3DSpellE>Querymap</span> layer, set to <span =
class=3DSpellE>hilite</span>
in a bright yellow <span class=3DSpellE>colour</span>, but I’ve =
noticed
that for polygons layers where I’ve only defined an <span =
class=3DSpellE>Outlinecolor</span>
and no fill color, only a narrow outline gets highlighted, not the =
feature
itself. As a result you have to squint at the screen to determine what =
features
are actually “highlighted”. I could change my map file so =
that all
polygon layers are filled, but this seems extreme. Is there <span =
class=3DGramE>an
other</span> way to highlight the whole feature, or change the highlight
outline to a thicker line?<o:p></o:p></span></font></p>
font-family:Arial'>Thanks.<o:p></o:p></span></font></p>
<p class=3DMsoAutoSig><font size=3D3 color=3Dnavy face=3D"Times New =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>------------------=
------------</span></font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Mark =
Adams</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Business & =
Systems
Analyst</span></font><span =
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Cuesta Systems =
Inc.</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>5230 South =
Service Road</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Burlington, ON =
L7L 5K2</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Phone: =
905-333-4544 x14</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Fax: =
905-333-0455</span></font><span
Roman"><span
style=3D'font-size:12.0pt;color:navy;mso-no-proof:yes'>Email:
markadams at cuestasys.com</span></font><span =
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0011_01C45AD9.05EC6CC0--
