[Mapserver-users] Using the shapefile FID in a query
Huey Brantley
huey.brantley at vanderbilt.edu
Mon Jun 28 14:14:18 EDT 2004
This is a multi-part message in MIME format.
--------------090001050406050102070200
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Do you get a OBJECTID field returned? If so, that's the FID.
Steve Lime wrote:
>Can you share a shapefile? Did you create the FID field or is some other piece of software reporting its existance? ArcView will show a sequential number but that's not part of the shapefile. You might also share your script, or at least a bit of it. Queries do return an index number and that can be used to retrieve features individually. I assume the INDEXQUERY mode of the CGI program is also present in MapScript using something queryByIndex method...
>Steve
>>>>"Mark Adams" <markadams at cuestasys.com> 06/28/04 11:52 AM >>>
>I'm puzzled over the behaviour of mapserver in returning query results
>from shapefiles. It appears the FID field which is present in all of the
>shape files I'm using does not get returned by mapserver when we use any
>of the mapscript query functions. There is no error, the field simply
>isn't present in the return value. Is this by design, and is there a way
>around this?
>This is causing me trouble as I need to have a generic way of
>identifying a specific (unique) feature. For example, if I query a layer
>and get back a list of 8 results from that query, I want to present
>these to the user and give them the option of separately clicking on and
>zooming to each of those items. To zoom and highlight a specific item I
>need to use the FID * it's the only unique key I can count on.
>Thanks in advance.
>Mark Adams
>Business & Systems Analyst
>Cuesta Systems Inc.
>5230 South Service Road
>Burlington, ON L7L 5K2
>Phone: 905-333-4544 x14
>Fax: 905-333-0455
>Email: markadams at cuestasys.com
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: multipart/related;
boundary="------------010309080703020309050008"
--------------010309080703020309050008
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body bgcolor="#ffffff" text="#000000">
Do you get a OBJECTID field returned? If so, that's the FID.<br>
<br>
<br>
<img src="cid:part1.05020200.01090904 at vanderbilt.edu" alt=""><br>
<br>
Steve Lime wrote:
<blockquote cite="mids0e01285.076 at co5.dnr.state.mn.us" type="cite">
<pre wrap="">Can you share a shapefile? Did you create the FID field or is some other piece of software reporting its existance? ArcView will show a sequential number but that's not part of the shapefile. You might also share your script, or at least a bit of it. Queries do return an index number and that can be used to retrieve features individually. I assume the INDEXQUERY mode of the CGI program is also present in MapScript using something queryByIndex method...
Steve
</pre>
<blockquote type="cite">
<pre wrap="">"Mark Adams" <a class="moz-txt-link-rfc2396E" href="mailto:markadams at cuestasys.com"><markadams at cuestasys.com></a> 06/28/04 11:52 AM >>>
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->I'm puzzled over the behaviour of mapserver in returning query results
around this?
Thanks in advance.
Mark Adams
Cuesta Systems Inc.
Fax: 905-333-0455
Email: <a class="moz-txt-link-abbreviated" href="mailto:markadams at cuestasys.com">markadams at cuestasys.com</a>
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
</pre>
</blockquote>
</body>
</html>
Content-Type: image/jpeg;
name="fid.jpg"
Content-Transfer-Encoding: base64
Content-ID: <part1.05020200.01090904 at vanderbilt.edu>
Content-Disposition: inline;
filename="fid.jpg"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--------------010309080703020309050008--
--------------090001050406050102070200--
