[Mapserver-users] WFS Layer Problem
Keith Campbell scoota at supanet.com
Wed Mar 3 18:41:48 EST 2004
Hi Bart,
The answer to your first question is 'none', and this is where the
problem obviously was. A lack of understanding on my part of the
mechanisms involved. Anyway, your response pointed me in the right
direction and I now have GML spewing forth, gallons of it. Now what to
do with it?
Just for the record, here's the request string that works:-
http://localhost/cgi-bin/mapserv_40.exe?map=F:/CDS%20Project/Working/Dev/MapServer/firstWFS.map&service=WFS&version=1.0.0&request=GetFeature&TypeName=UrbanAreas
Thanks for your help.
Keith
bartvde at xs4all.nl wrote:
>Hi,
>what kind of request are you doing against the WFS? Is the GetCapabilities
>working on your WFS (&service=WFS&request=GetCapabilities) ?
>Below a setup from my server which works:
>  WEB
>    IMAGEPATH "/ms4w/tmp/ms_tmp/"
>    IMAGEURL "/ms_tmp/"
>    METADATA
>      WMS_TITLE "Gemeentes mapserver WMS"
>      WMS_ABSTRACT "UMN MapServer Gemeentekaart"
>      WMS_ACCESSCONSTRAINTS none
>      WMS_SRS "EPSG:28992"
>      WFS_TITLE "Gemeentes mapserver WFS"
>			WFS_ONLINERESOURCE
>"http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/general/map/gemeentes.map"
>			WFS_SRS "EPSG:28992"
>			OWS_SCHEMAS_LOCATION "http://ogc.dmsolutions.ca"
>    END
>  END
>  LAYER
>      DATA "Nlge_r98"
>        METADATA
>          WMS_TITLE "Gemeentes"
>          WMS_ABSTRACT "Gemeentes via UMN Mapserver"
>          WFS_TITLE "Gemeentes"
>        END
>      NAME "Gemeentes"
>      SIZEUNITS PIXELS
>      STATUS ON
>      TOLERANCE 0
>      TOLERANCEUNITS PIXELS
>      TYPE POLYGON
>      DUMP TRUE
>      TEMPLATE "blank.html"
>      UNITS METERS
>      CLASS
>        NAME "Foreign Lands"
>        STYLE
>          MAXSIZE 100
>          MINSIZE 1
>            OUTLINECOLOR 255 0 0
>          SIZE 1
>          SYMBOL 0
>        END
>      END
>    END
>Best regards,
>Bart
>>Hi All,
>>I'm trying to set up a map file to serve up a WFS layer. I think I've
>>set all the metadata tags specified in the HOWTO but I get a GIF output,
>>not GML. I'm using v4.0 on Windows. Here's the mapfile:-
>>MAP
>>  DEBUG TRUE
>>  NAME "FIRST"
>>  SHAPEPATH "F:\CDS Project\Mapping\shp\"
>>  EXTENT 270000 180000 290000 200000
>>  SIZE 600 600
>>  UNITS METERS
>>  WEB
>>    IMAGEPATH "F:\CDS Project\Working\Dev\MapServer\tmp\"
>>    IMAGEURL "/CDSproj/Dev/MapServer/tmp/"
>>        LOG "F:\CDS Project\Working\Dev\MapServer\MapServer.log"
>>    METADATA
>>      "wfs_title"                  "WFS Demo - CDS Project"
>>      "wfs_onlineresource"
>>"http://localhost/cgi-bin/mapserv_40.exe?map=F:/CDS%20Project/Working/Dev/MapServer/firstWFS.map"
>>      "wfs_srs"                   "EPSG:27700"
>>      "ows_schemas_location"
>>"http://ogc.dmsolutions.ca/wfs/1.0.0/WFS-basic.xsd"
>>    END
>>  END
>>  # Start of LAYER DEFINITIONS
>>  LAYER # UrbanAreas polygon layer begins here
>>    NAME UrbanAreas
>>    DATA UrbanAreas
>>    STATUS DEFAULT
>>    TYPE POLYGON
>>        DUMP TRUE
>>    CLASS
>>      STYLE
>>        COLOR 232 232 232
>>        OUTLINECOLOR 32 32 32
>>      END
>>    END
>>  END # UrbanAreas polygon layer ends here
>>  # End of LAYER DEFINITIONS -------------------------------
>>END # end of map file/object
>>Can anybody see what else needs to be added to force the output to GML?
>>Thanks,
>>Keith
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
