[Mapserver-users] Compiling on Win32
Sean Gillies
sgillies at frii.com
Tue Mar 9 13:54:35 EST 2004
On Mar 9, 2004, at 11:22 AM, PLAIRE Rory wrote:
> Greetings,
> Many thanks to all who work on Mapserver... a great tool to bring GIS
> closer
> to everyone!
> I am trying to compile Mapserver on Win32 so that I can create a C#
> wrapper
> with SWIG. Two issues come up: 1) I can't find documentation on how to
> generate mapparser.h from mapparser.y, although I've used Flex to no
> avail
> and 2) It isn't clear how to generate Mapserver as a DLL, although I
> know
> that some editing of the build will be needed.
> I am lamentably green in the VC++ build process, so these questions
> will
> take me some time to iron out. Perhaps someone would be kind enough to
> point
> to the right direction to start me off.
> Appreciative,
> -rory
> Rory Plaire
> GIS Programmer/Analyst
> Benton County, Oregon
Rory,
Have you considered the possibility of using a well-supported mapscript
interface such as Perl/PHP/Python/Ruby with your .NET framework? Here
are
a few links I found which offer some degree of interoperability between
mapscript and .NET -- mapscript applications programmed in
Perl/Python/Ruby
and compiled for the .NET runtime:
http://zope.org/Members/Brian/PythonNet/
http://www.activestate.com/Corporate/Initiatives/NET/Research.html?_x=1
http://www.saltypickle.com/rubydotnet/
I'm not trying to discourage you from a SWIG C# interface ... but if you
are new to compiling MapServer, you are probably facing *many* hours
pioneering
a C# interface. There is no work committed to the MapServer code base
to help
you and as far as I know there is no one out there who has anything to
share.
Could be that there is a SWIG C# interface out there which is being held
out of the public domain (hello dgraham?), but I can't say.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
