[SPAM] - Re: [Mapserver-users] Retrieving shape extent -
Email found in subject
Steve Lime
steve.lime at dnr.state.mn.us
Mon Mar 15 14:49:18 EST 2004
Assuming you're using a query map you'd just use the [img] tag to get at
the
image. No extra trip necessary. You can also build images based on
query results
independent of the query map.
Steve
>>> "Charles D. Van Dusen" <charlie at im-design.net> 3/15/2004 1:16:03 PM
OK (understood)
So, how do I get the map while in non-map mode? Does it require an
extra
round-trip to the server or is the image created?
Im working with the 'workshop' demos (specifically the dhtml banding
box
demo), which I believe has its template specified as
'itasca_adds_dhtml.html'.
TIA
Charlie
Charlie Van Dusen
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, March 15, 2004 1:15 PM
To: Charles D. Van Dusen; mapserver-users at lists.gis.umn.edu
Subject: [SPAM] - Re: [Mapserver-users] Retrieving shape extent -
Email
found in subject
When you're in a ...MAP mode you only get the map, that's the point.
However you can
still get a map with in a non-map mode, but you work through a
template
instead. Won't that work for you?
Steve
>>> "Charles D. Van Dusen" <charlie at im-design.net> 3/13/2004 11:38:59
AM >>>
Greetings All,
Is it possible to retrieve the extent of a shape selected whil in
'indexquerymap' mode?
So far I have not been able to retrieve anything but the image of the
selected shape. I need to have the extent ([shpext]) as well, but I
have
only been able to retrieve it in 'indexquery' mode.
Any ideas
Thanks
Charlie
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
