[Mapserver-users] Re: demo: legend, scalebar
Jerl Simpson jerl.simpson at rkiq.com
Mon May 3 09:00:56 EDT 2004
Matt,
You can find an quick example of how to read the TIGER/Line data here:
http://mapserver.gis.umn.edu/doc40/ogr-howto.html#binary
scroll down to example #3.
I have done this, and it does work.  However I would recommend
converting the ASCII files to ESRI Shapefiles.  The ESRI files will
allow maps to be displayed much faster.  If you have a small amount of
data, it might be alright.  As you add data however, it will slow down
as ASCII is not very effecient for searching.
Jerl
malonso at meso.com wrote:
> Hello,
> Has anyone come across or developed any utilities that can incorporate
> TIGER line files?  I also included a previous question (below) that I
> hadn't gotten any response to, if you can help with either that would be
> greatly appreciated.  Thanks folks.
> Matt
>>Howdy all,
>>I am trying to run the demo, and I can get most of it to work, but I
>>can't seem to get the legend or the 1st scalebar, the main map and the
>>2nd bar in the bottom right corner works fine.  I attached the modified
>>index.html and itasca.map files.  Ironically I had them all working fine
>>at first, but I had set the various "image_" things wrong so I could not
>>see them.  I made a couple changes and looked in the dir where the
>>images should've been and they were all there.  All the previous legends
>>and scalebars where there from the previous runs, but I was no longer
>>able to generate the 1st scalebar and the legends.  If anyone needs
>>anymore info please let me know.  Thanks in advance for your help.
>>Matt
> Matt Alonso
> Meso, Inc.
> 185 Jordan Road
> Troy, NY 12180
> phone: 267-446-8657
> work: 518-283-5169
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
