[Mapserver-users] mapserver on mandrake
Sébastien DUBOIS sebastien.dubois at esm2.imt-mrs.fr
Mon May 3 09:28:05 EDT 2004
hello,
I have used "urpmi" to install mapserver under Mandrake9.2
So like Paco Regodon i've got the mapserver-4.0-1mdk, the rpm package from
Mandrake
I install apache by the same way (urpmi apache) then i made
> apachectl start
is that enough to start apache?
mapserv is in /var/www/
bu
[root at sx-dubois sbin]# which apachectl
/usr/sbin/apachectl
so mapserv and apache are not in the same directory !!!
I verified carefully that all the requires were installed
Requires
    * webserver
    * libc.so.6
    * libcrypto.so.0.9.7
    * libcurl.so.2
    * libdl.so.2
    * libfreetype.so.6
    * libgd.so.2
    * libgdal.1.1.so
    * libjpeg.so.62
    * libm.so.6
    * libpng.so.3
    * libproj.so.0
    * libssl.so.0.9.7
    * libstdc++.so.5
    * libtiff.so.3
    * libz.so.1
but when I test on my favourite browser:
http://sx-dubois@rd.francetelecom.com/var/www/cgi-bin/mapserv
I can red:
Warning: Failed opening '../../../fr/navigation/cadres.php' for inclusion
(include_path='.:/usr/local/lib/php') in /export/WWW/fr/navigation/bar.php on
line 40
Warning: Failed opening '../../../fr/navigation/ftbar.php' for inclusion
line 41
Warning: Failed opening '../../../fr/navigation/rubriques.php' for inclusion
line 42
Fatal error: Call to undefined function: rd_head() in /export/WWW/404.html.php
on line 27
Have you got a explanation for that?
thanks in advance for the time you spend to help me...
Sébastien DUBOIS
Ecole Généraliste d'Ingénieurs de Marseille (ex ESM2)
1024D/A1140BCB
Empreinte de la clé = 1BC8 7E21 4DA7 13D5 1B5F  876F F719 2B7A A114 0BCB
disponible sur www.keyserver.net
This mail sent through IMP: http://horde.org/imp/
