[Mapserver-users] Which is better: PHPMapScript query engine or PHP dBase functions?
Ryan, Adam ARyan at co.linn.or.us
Mon May 3 14:38:32 EDT 2004
Eduardo,
I might be off track but...
I thought about this myself.  In order to display the result shapes you need
to have a query result either from doing the query in mapscript or loading a
saved query file.  The former defeats the point of querying the dBase since
you're duplicating your steps, and the later requires you to manually build
a query file but you can't do that unless you can get at the dBase record -
shapefile index relationship which I don't know how to do.
Again, I may be off track, but querying the dBase file may not be feasible.
Adam
-----Original Message-----
From: Eduardo Patto Kanegae [mailto:eduardo at consultoria.eti.br]
Sent: Monday, May 03, 2004 11:06 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Which is better: PHPMapScript query engine or PHP
dBase functions?
I have a mapserver+php+mapscript that will query on a shapefile database on
a single layer, through its atributes.
The system will give as result a set of items on a result list as a first
step.
Then as a second step a map displaying these results should be given.
my doubt is: to create this result list which will be best strategy:
- use PHPMapScript to query against the mapfile ?
or
- simply use PHP dBase functions to query against dBase files of the
mapfile?
which one is the best/fastest alternative?
best regards.
http://www.consultoria.eti.br
UIN: 303747254
I Encontro Nacional de Usuários MapServer -
http://mapserver.cttmar.univali.br/encontro2004
Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
***Fim da Mensagem / End of Message ***
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
