[Mapserver-users] Generating dynamic point layer
Paul Dymecki
pdymecki at sympatico.ca
Thu May 13 00:22:47 EDT 2004
Hi Joost,
Is there a way of doing joins between 2 odbc tables with OGR?
Thanks,
Paul Dymecki
----- Original Message -----
To: "'David Fawcett'" <David.Fawcett at state.mn.us>; <samuzzal at linux.net>;
<fx.prunayre at oieau.fr>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, May 12, 2004 2:11 PM
Subject: RE: [Mapserver-users] Generating dynamic point layer
> Hi David,
> You can use OGR to connect to your access database. Consider the
following
> layer object:
> LAYER
> NAME OGRPoints
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION
> '<OGRVRTDataSource>
> <OGRVRTLayer name="MyPoints">
> <SrcDataSource>ODBC:MySystemDSN,MyTable</SrcDataSource>
> <SrcLayer>MyTable</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="MyXColumn"
> y="MyYColumn"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>'
> DUMP TRUE # for WFS only
> DATA "MyPoints"
> STATUS default
> CLASS
> SYMBOL 'circle'
> SIZE 25
> COLOR 255 0 0
> END
> END
> You can do this for any ODBC compliant db. Let me know if you need
anything
> further.
> Regards,
> Joost van Ulden
> Programmer/Analyst
> Natural Resources Canada / Ressources naturelles Canada
> Geological Survey of Canada / Commission geologique du Canada
> 101 - 605 Robson Street / 101 - 605 rue Robson
> Vancouver, B.C. / Vancouver (C.B.)
> V6B 5J3
> Office/Bureau: 604.666.7525
> fax/telecopieur: 604.666.1124
> jvanulde at nrcan.gc.ca
> -----Original Message-----
> From: David Fawcett [mailto:David.Fawcett at state.mn.us]
> Sent: Wednesday, May 12, 2004 7:14 AM
> To: samuzzal at linux.net; fx.prunayre at oieau.fr
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Generating dynamic point layer
> Has anyone successfully created point layers from Access .mdb files?
> David J. Fawcett
> MN Office of Environmental Assistance
> >>> François-Xavier Prunayre <fx.prunayre at oieau.fr> 5/12/2004 4:47:23 AM
> > I have an access table with the georeferencing positions (X, Y).
> > Could anybody please help me by sending some code to generate a point
> > layer dynamically from these information. Thanks for previous helps I
> > got from the group.
> You could do that using OGR virtual layer; Wiki page is
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData.
> Set DSN in odbc connection; for exemple French,
> then Ovf file look like this :
> <OGRVRTDataSource>
> <OGRVRTLayer name="STATIONS">
> <SrcDataSource>ODBC:French,STATIONS</SrcDataSource>
> <SrcLayer>STATIONS</SrcLayer>
> <LayerSRS></LayerSRS>
> x="X_LAMBERT_II_ET" y="Y_LAMBERT_II_ET"/> </OGRVRTLayer>
> </OGRVRTDataSource> where X_LAMBERT_II_ET is X coordinates and
> Y_LAMBERT_II_ET is Y.
> Map file layer tag is :
> LAYER
> NAME OVF
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "french.ovf"
> DATA "STATIONS" # the name of the OGRVrtLayer
> STATUS DEFAULT
> PROJECTION
> "init=epsg:27582"
> END
> DUMP TRUE
> CLASS
> TEMPLATE "ttt_query.html"
> SYMBOL "circle"
> SIZE 6
> NAME "STATION_FR"
> OUTLINECOLOR 239 16 16
> END
> END
> You could also use Mapscript.
> HTH
> Francois
> From: "Sam Choudry" <samuzzal at linux.net>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, May 12, 2004 9:27 AM
> Subject: [Mapserver-users] Generating dynamic point layer
> > Hello group,
> > Samuzzal
> > _____________________________________________________________
> > Linux.Net -->Open Source to everyone
> > Powered by Linare Corporation
> > http://www.linare.com/
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Ce message a ete verifie par MailScanner pour des virus ou des
polluriels
> et rien de suspect n'a ete trouve.
> > Les donnees et renseignements contenus dans ce message sont
> > personnels,
> confidentiels et prives. Toute publication, utilisation ou diffusion, meme
> partielle, doit etre autorisee.
> > Any data and information contained in this electronic mail is
> > personal,
> confidential and secret. Any total or partial publication, use or
> distribution must be authorized.
> Ce message a ete verifie par MailScanner pour des virus ou des polluriels
et
> Les donnees et renseignements contenus dans ce message sont personnels,
> Any data and information contained in this electronic mail is personal,
