[Mapserver-users] Hyperlinks from map layers
Michael Schulz mschulz at webgis.de
Mon May 17 06:10:30 EDT 2004
Hi Kenneth,
an easy way to do this, is to open a new browser window and then define
the location of the new window with javascript:
Therefore you need a JS function in your query template that assigns the
new href location:
function openLink() {
   detail = window.open("","Detail","toolbar=no");
   detail.location.href = "http://www.yourserver.dk/pdf_dir/[DBF_PDF_LINK]";
Call this function from <BODY onload="openLink();">.
HTH, Michael
Kenneth Slot schrieb:
> I have a 2 layers called plan_poly the other called plan_line. As the
> title says on layer type is Polygon and the other is Line.
> Both layers contains the same columns Title, Desciptions and Doclink.
> The doclink contains link to a given PDF document on a webserver.
> http://www........../1-1.pdf
> I want to makes these doclinks active as hyperlinks, so i can click on
> the map with the "i" button and be redirected to the pdf-document.
> Is that possible? If so how do i activate my layers?
> I'm using MapLap and Mapserver newest version. On Microsoft Internet
> Informations Server.
> Thanks
> Kenneth
Michael Schulz                                in medias res
Dipl.-Geologe                              Gesellschaft für
                                 Informationstechnologie mbH
                                      In den Weihermatten 66
		                             79108 Freiburg
                                      0761 55695-95 (Fax 96)
mschulz at webgis.de              www.webgis.de/www.zopecms.de
