[Mapserver-users] pointObj method 'draw'
Manfred Meier
m.meier at spiekermann.de
Tue May 18 00:12:25 EDT 2004
Thank you Sean,
for your explanations. Sometimes some background information is
necessary to understand why an api does this and not that.
> In my opinion, pointObj::draw and shapeObj::draw are
> elements of bad design and we shouldn't increase bad design with a
> lineObj::draw
Can you give me one cue why it is bad design?
Thanks
Manfred
Sean Gillies schrieb:
> Manfred,
> Why the difference?
> First, it must be understood that the development of the MapServer software
> is primarily driven by advances in the mapserv program, and that the
> mapscript module has been developed by wrapping structures and functions
> used in mapserv. I don't think that the mapscript module has been through
> much design, rather it grows by judicious accretion of features from
> mapserv.
> In mapserv, lines are only drawn within the context of layer features or
> within the context of a legend, hence there is no drawing of lines only,
> only the function that we wrap to use with shapeObj::draw.
> Because of the need for annotation, there are functions to draw points
> outside of the layer feature context and this is the basis for
> pointObj::draw.
> You are right that the mapscript API implies that there may exist a
> lineObj::draw, and I agree that such a function could be useful. However,
> I am not in favor of extending the general drawing features of mapscript
> in the current API. In my opinion, pointObj::draw and shapeObj::draw are
> lineObj::draw.
> Hope this explains, cheers,
> Sean
> On May 16, 2004, at 10:30 PM, Manfred Meier wrote:
>> Thank you for your answer, Daniel,
>> I knew that, and I would like to know, why there is this difference.
>> But it's not so very important.
>> Mapserver and mapscript are very helpful for me. I'm trying to display
>> the location of busses with information about delays.
>> Manfred
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
