[Mapserver-users] shapfiles 2 MS-SQL Server
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Tue May 18 10:09:59 EDT 2004
I think the only way to connect MapServer with MSSQL will be using ArcSDE.
http://www.consultoria.eti.br
UIN: 303747254
I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
***Fim da Mensagem / End of Message ***
On Mon, 17 May 2004 14:06:31 +0700, taufan at ebdesksolutions.com escreveu:
> De: taufan at ebdesksolutions.com
> Data: Mon, 17 May 2004 14:06:31 +0700
> Para: Eduardo Patto Kanegae <eduardo at consultoria.eti.br>
> Assunto: Re: [Mapserver-users] shapfiles 2 MS-SQL Server
> Thank's for your explanation.But i'm still confuse,where I must write the
> connection, in .map as connection type & Connection or in html?
> Sorry I'm new in mapserver.Is there different way if i want connect to mssql and
> to postGIS? Could you explain to me (maybe with some sample) tecnically the way
> to do that (MSSQL-Map Server)??
> Thank you.
> Emanuel Taufan
