[Mapserver-users] Mixed Units (DD & Meters)
Michael Cortez mcortez at fullcoll.edu
Tue May 18 16:45:24 EDT 2004
> I'd like to keep the output in DD, but have some select
> layers sources be in Meters.  Is this possible?  Is there an
> example for setting up this type of PROJECTION or doing this
> conversion on the fly?
I know, replying to my own message... Bad, Bad...
But...
I've gotten closer -- digging through the archives, and taking a look at
the map recipes (thanks Hal) I've "cobbled together" something that
almost works.
MAP
  EXTENT -8000000 300000 5000000 1500000
  UNITS METERS
  PROJECTION
    "proj=lcc" "lat_1=32" "lat_2=44" "lat_0=38" "lon_0=-100" "x_0=0"
"y_0=0" "ellps=WGS84" "datum=WGS84"
  END
  LAYER
    PROJECTION  # Got this from recipe when I noticed it was using the
same source data.
      "proj=latlong"
      "ellps=WGS84"
      "datum=WGS84"
    END
  END
  LAYER
    PROJECTION
      "proj=aea"
      "lon_0=-120"
	"ellps=clrk66"
	"lat_0=142"     # Guessed this
    END
  END
END
For the lat_0 on my aea layer, I guessed that value.
I added the layer without it, and looked at the results, and my
California data was down next to Central America.  So I added a lat_0
keyword, and played with the value until I got it overlay on top of the
California state projected by my other layer.  I doubt I've done this
correctly.  So any suggestions on the correct way of determining the
projection info for my 2nd layer?
Thanks,
Michael Cortez
Development Services
Academic Computing
Fullerton College
http://www.fullcoll.edu
