[Mapserver-users] php_mapscript401 doesn't display points
Eric Bridger
eric at gomoos.org
Thu May 20 13:10:30 EDT 2004
At 05:52 PM 05/20/2004 +0200, Geoprogetti Informatica wrote:
>Hi all,
>I updated my application from php_mapscript366 to php_mapscript401 in
>win2000 server (IIS5).
>401 version doesn't display point shapefile. When I set the reference to 366
>version in my code, the point
>shapefile returns in the map. Lines and polygons seem to work fine with both
>versions.
>This is the mapfile:
>MAP
> NAME "test"
> STATUS ON
> #EXTENT 1316000 4034000 2310000 5241000
> EXTENT 1552554 4673500 1773000 4929127
> SIZE 600 600
> FONTSET fontset.txt
> SHAPEPATH "shape"
> IMAGECOLOR 255 255 255
> UNITS METERS
> SYMBOLSET symbol.sym
>#IMAGETYPE PNG
> WEB
> HEADER toscana_header.html
> TEMPLATE query.phtml
> FOOTER toscana_footer.html
> MINSCALE 10
> MAXSCALE 8500000
> IMAGEPATH "C:\inetpub\wwwroot\tmp\"
> IMAGEURL "/tmp/"
> END
>REFERENCE
> STATUS ON
> IMAGE "ref.gif"
> SIZE 120 126
> EXTENT 1313238 4072162 2312138 5220403
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
>END
>SCALEBAR
> LABEL
> COLOR 0 0 0
> END
> STYLE 0
> SIZE 100 2
> BACKGROUNDCOLOR 200 200 200
> COLOR 0 0 0
> UNITS METERS
> INTERVALS 1
> TRANSPARENT FALSE
> STATUS TRUE
> IMAGECOLOR 255 255 221
>END
>QUERYMAP
> COLOR 255 255 0
> STATUS ON
> STYLE HILITE
>END
>LAYER
> NAME ""
> GROUP "test"
> TYPE POINT
> STATUS On
> DATA 'test'
> CLASSITEM 'Name'
> TEMPLATE "ttt.html"
> CLASS
> NAME "pp"
> EXPRESSION /./
> SYMBOL 'test'
> SIZE 12
> END
>END
>END
Try adding a STYLE to your CLASS object:
CLASS
NAME "pp"
EXPRESSION /./
STYLE
SYMBOL "test"
SIZE 12
END
END
