[Mapserver-users] emacs mode for .MAP files
Hal Mueller hal at mobilegeographics.com
Mon May 24 04:05:52 EDT 2004
I've put together a fairly simple MapServer mode for the Emacs text
editor.  I've been using the module for a few days now under GNU
Emacs and it works pretty well.  Haven't tested under XEmacs, but I
expect it would work fine there too.
You can download the mode at
http://www.mobilegeographics.com/mapserver/mapserver-mode.el
The main thing this mode does is indentation.  Your code will be
indented as you type it, or you can reindent/reformat an entire file
at once.  It also does some keyword highlighting, but I rarely care
about that myself so haven't worked that feature very much.
Known bug:
Constructs like the one below will add an extra indent level:
     PROJECTION "xxxx" "yyyy" "zzzz" END
         CLASS ....
Instead, use this style:
     PROJECTION
     END
     CLASS
(the problem arises for POINTS 1 1 END and anything similar).
I don't have this code checked into any CVS, so if you have
mods/bugfixes, please email me directly.  If you have a MAP file that
doesn't format correctly, please send me the file (and a comment
about what doesn't work).  License for this Emacs mode is the same as
the MapServer license (and _not_ the GPL).
Hal
