[Mapserver-users] Create a legend using PHPMapscript
    Van Ulden, Joost
    jvanulde at nrcan.gc.ca
    Wed May 26 14:42:00 PDT 2004
You can use legend templates or code your own.  Here is a function that will
do it for you (excuse the formating!):
// draw the legend
	function drawLegend($layerArray) {
		GLOBAL $map;
		// get the list of layers
		$aLayerList = $map->getAllLayerNames();
		$aLayerList = array_reverse($aLayerList);
		$aSentLayers = explode(",",$layerArray);
		//loop through layers
		foreach($aLayerList As $sName)
			$currentLayer = $map->getLayerByName($sName);
			// check if layer is passed and if it was set the
status to on
			if ($currentLayer->status != 2)
				foreach($aSentLayers As $testName){
					if($sName == $testName)
						$currentLayer->set(status,
1);
					} else {
0);
			$currentName = $sName;
			$currentTitle =
$currentLayer->getMetaData("WMS_TITLE");
			$currentStatus = $currentLayer->status;
			$checked = "";
			// set the checked status of layer
			if ($currentStatus == 1)
				$checked = '<INPUT type="checkbox"
name="layer" value="'.$currentName.'"
onClick="mapForm.redraw.value=true;mapForm.submit()" CHECKED >';
			} elseif ($currentStatus == 0){
onClick="mapForm.redraw.value=true;mapForm.submit()" >';
			// write out the title
			echo '<TR bgcolor="#CCCCCC"><TD
colspan="2"> '.$checked.$currentTitle.'</TD></TR>';
			if ($currentStatus >= 1)
				//get the number of classes for this layer
				$nClassCount = $currentLayer->numclasses;
				// loop through the classes
				for($j=0; $j<$nClassCount; $j++)
					$currentClass =
$currentLayer->getClass($j);
					$className = $currentClass->name;
					$classImage =
$currentClass->createLegendIcon(20,10);
					$classImageUrl =
$classImage->saveWebImage(MS_GIF,1,0,90);
					// write out the html code
					echo '<TR bgcolor="#FFFFFF"><TD><IMG
src="'.$classImageUrl.'"></TD><TD>'.$className.'</TD></TR>';
Good luck!
Joost van Ulden
Programmer/Analyst
Natural Resources Canada / Ressources naturelles Canada
Geological Survey of Canada / Commission geologique du Canada
101 - 605 Robson Street / 101 - 605 rue Robson
Vancouver, B.C. / Vancouver (C.B.)
V6B 5J3
Office/Bureau:  604.666.7525
fax/telecopieur: 604.666.1124
-----Original Message-----
From: Frank Broniewski [mailto:Frank.Broniewski at mnha.etat.lu]
Sent: Wednesday, May 26, 2004 6:25 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Create a legend using PHPMapscript
Dear List
I'm still a beginner with MapServer, so I have trouble understanding the
process of creating a legend using php-mapscript. Maybe a reader may send me
on the right path.
I've done so far this tutorial
   http://mapserver.gis.umn.edu/doc/phpmapscript-byexample-howto.html
And the tutorials found here
   http://terrasip.gis.umn.edu/projects/tutorial/
Which provide quite some background
But when it comes to creating the legend dynamically, I can't seem to find
any helpful source. And I must admit, that I'm not capable of understanding
the information provided here:
   http://mapserver.gis.umn.edu/doc/phpmapscript-class-guide.html#legend
As far as I understand inherits the legend object from the mapobject. So I
thought it might be a good idea to create the legend in the same manner as
the scalebar, which I could figure out myself :-) To provide a little more
information on my work, here is the code I
used:
  $legend = $map->legend();
  $legend_url = $legend->saveWebImage();
Am I missing vital parameters or something else? I'm currently displaying
one shapefile only in my map.
Thanks a lot in advance of your help and kind greetings from Luxembourg
Frank Broniewski
Musée National d'Histoire et d'Art
Section Préhistoire / Projet EPC
    Tél: +352 260 281-21
241, Rue de Luxembourg
L-8077 Bertrange
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
