[Mapserver-users] virtual spatial data
Chip Hankley
Chip.Hankley at rmtinc.com
Thu May 27 14:52:50 EDT 2004
> Try dependency walker (http://www.dependencywalker.com/) - it should
> tell you the versions...
OK. It appears that the mapserv.exe is using GDAL12.DLL. The "File Time
Stamp" reported in Dependancy Walker is 5/11/2004, 1:45a. This is the
4.2 beta binary from the mapserver site. I downloaded this a few days
ago.
> Can you confirm that you are able to get back your data via the
virtual
> driver (using an ovf file) from the command line? This is different
> from using ogrinfo with the odbc driver directly.
ogrinfo -ro virtual.ovf
...returns
INFO: Open of `virtual.ovf'
using driver `VRT' successful.
1: MyLayer (Point)
ogrinfo -ro virtual.ovf mylayer
...returns (lots of data)
<snip>
OGRFeature(MyLayer):132
ID (Integer) = 133
MEDIA (String) = WST
SURVEYUNIT (String) = SU2
Y (String) = 792861.455961
X (String) = 13238236.349609
POINT (13238236.350 792861.456 0.000)
</snip>
Outgoing messages, along with any attachments, are scanned for viruses at RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient. Any review or distribution
by others is strictly prohibited. If you are not the intended recipient,
please contact the sender immediately and delete all copies.
