[Mapserver-users] selection hilite_ basic question
Janeks Kamerovskis
janeks.kamerovskis at silva.lv
Fri May 28 02:02:23 EDT 2004
I made working map example a bit modified to see my own maps.
(on Win2000 and IIS)
Then added to query layer definition:
TEMPLATE 'C:\bla\path\mapTemplate.html'
that was the same template, that I was using for that working exapmle.
Then by changing in url parameters &mode=itemquery
and adding
&qlayer=layername&qitem=atribFieldName&qstring=aquerystrng&mapext=shapes
It worked well.
Now I just have to add a search control in my map template file
brgds
Janeks
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of andre shue
Sent: Thursday, May 27, 2004 5:58 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] selection hilite_ basic question
Hi Steve and List,
I am pretty new and unexperienced to the MS, it might be a stupid quest...
anyway, I got the demo running, changed some layers, but when selecting a
polygon via itemquery I am not sure. I can do an attribut search and also
get results via template [area] [name] yet no map. I know I can get a map
via querymap, but could not go any further on this.
I dont know how to build up an template with a map, including the selected
polygon marked and in the centre of the map....
As the where any examples I would be happy.
As you have any hints, please remember, I am a Geographer and low level
programmer.
Thanks a lot.
Andreas
PS. Another question is, is there a list of the complete template and map
commands, I got the feeling there are some more commands, than I could find
via the Mapserver homepage.
Thanks anyway to the great developers of mapserver
Here is the template and the map.
<!-- START OF MAPSERVER FORM -->
<form name="mapserv" method="GET" action="mapserv.exe">
<table width="400" border="0" align="center">
<tr>
<td>
<p align="center"><font face="Arial Narrow"> </font>
<font face="Arial Narrow" size="6">Muldentalkreis MS
Test</font></p>
<p> </p>
<table width="466" border="1">
<tr>
<td width="211">
<!-- SPECIFY MAP MODE -->
Attribut eingeben<b> (Achtung!!! Mapmode = Attributabfrage)</b><div
align="center">
<input type="TEXT" size= "30" name= "qstring" value=""><input type="submit"
value="ENTER"></div>
<div align="center"> </div>
<div align="center">Map Mode:<br>
<select name="mode">
<option value="browse" [browse_select]>Browse</option>
<option value="query" [query_select]>Abfrage</option>
<option value="itemquery" [itemquery_select]>Attributabfrage</option>
</select>
</div>! ;
</td>
<td width="77">
<!-- FORM SUBMIT BUTTON -->
<input type="submit" name="submit" value="Refresh">
</div>
</td>
<td width="156">
<!-- ZOOM/PAN CONTROLS -->
<div align="center">Map Control: <br>
<select name="zoom">
<option value="4" [zoom_4_select]>Zoom In 4x</option>
<option value="3" [zoom_3_select]>Zoom In 3x</option>
<option value="2" [zoom_2_select]>Zoom In 2x</option>
<option value="1" [zoom_1_select]>Recenter</option>
! ; <option value="-2" [zoom_-2_select]>Zoom Out
2x</option>
<option value="-3" [zoom_-3_select]>Zoom Out 3x</option>
<option value="-4" [zoom_-4_select]>Zoom Out 4x</option>
</select>
</div>
</td>
</tr>
<tr>
<!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE -->
<td colspan="3" align="center" valign="top" width="390">
&nb! sp; <input type="image" name="img" src="[img]" width="[mapwid th]"
height="[mapheight]">
</td>
</tr>
</table>
</td>
</tr>
</table>
<!-- Attributabfrage -->
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="root" value="[root]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="qlayer" value="mtl">
<input type="hidden" name="qitem" value="GEMEINDE"
</form>
</body>
</html>
MAP
IMAGETYPE PNG
EXTENT 4528581.187561 5713247.167603 4573608.666901 5651344.554810
SIZE 750 750
SHAPEPATH "data"
IMAGECOLOR 255 255 255
QUERYMAP
SIZE 600 600
STATUS OFF
STYLE HILITE
COLOR 23 35 24
END
WEB
TEMPLATE 'test.html'
IMAGEPATH 'tmp/'
IMAGEURL 'tmp/'
END
LAYER
NAME mtl
TYPE POLYGON
DATA mtl
PROJECTION
proj=tmerc
lat_0=0.000000000
lon_0=12.000000000
k=1.000000
x_0=4500000.000
y_0=0.000
ellps=bessel
units=m
no_defs
END #line114
STATUS DEFAULT
CLASSITEM 'GEMEINDE'
LABELITEM 'GEMEINDE'
#LABELMINSCALE 80000
CLASS
NAME "GEMEINDE"
EXPRESSION /./
OUTLINECOLOR 0 0 0
COLOR 255 255 217
LABEL
END
TEMPLATE "mtl.html"
END
HEADER "mtl_header.html"
FOOTER "mtl_footer.html"
END
MSN 8 helps ELIMINATE E-MAIL VIRUSES. Get 2 months FREE*.
_______________________________________________ Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
