[Mapserver-users] XML Mapfile
Daniel Morissette dmorissette at dmsolutions.ca
Fri May 28 15:28:13 EDT 2004
Stephen Woodbridge wrote:
> OK so SLD the same as Web Map Contexts?
> It also sounds like a bunch of this stuff is under active development.
> How much is ready for prime-time on 4.01 and 4.2?
> Is there documentation for it, sounds like I have a bunch of reading to do.
SLD is all there and stable in 4.2. With respect to docs, I don'
With respect to docs, it's still a draft that will eventually make it
into the official MapServer docs. This is the topic of a bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=625
The draft is there as an attachment to the bug.
> The only technical reason for going a different route is the fact that a
> lot of our infrastructure is based on mapscript, perl, php, etc.
> Converting it to work with WMS and SLD "might" be a lot bigger task than
> writing a mapfile -> XML -> mapfile converter.
I think SLD is the way to go: an SLD can easily be applied to a map
object inside a MapScript script, so I don't think you would need to
change your system that much.
The only drawback in your case may be the overhead of processing the
same SLD for every map request... but then you could just preprocess the
SLDs into mapfiles and that's still simpler than building a complete
mapfile -> XML -> mapfile convertor.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
