[Mapserver-users] Compiling problems ms 4.2+PHP5
Merlos
merlos at tsc.uvigo.es
Fri May 28 23:01:14 EDT 2004
Hello,
I'm trying to compile mapserver 4.2 and php5-RC2, has anybody succeed to
compile it with php5 or do I have to use PHP 4.3.x? I am doing something
wrong? Any advice?
This are my cofigure options:
./configure --with-proj --with-ogr --with-gdal --with-postgis --with-wfs
--with-wmsclient --with-httpd=/usr/sbin/apache
--with-php=/usr/local/include/php --with-tiff
and when I run make I got this message:
gcc -fPIC -O2 -Wall -DCOMPILE_DL=1 -DPHP4 -DUSE_WMS_LYR -DUSE_WFS_SVR
-DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_TIFF -DUSE_GDAL -DUSE_OGR -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_EPPL -DUSE_PDF -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT
-I/home/merlos/public_html/pub/geotools/mapserver/mapserver-4.2.0
-I/usr/local/include -I/usr/local/pgsql/include -I/usr/local/include
-I/usr/local/include -I/usr/local/include/php -I/usr/local/include/php/dl
-I/usr/local/include/php/main -I/usr/local/include/php/Zend
-I/usr/local/include/php/include -I/usr/local/include/php/TSRM -c -o
php_mapscript_util.o php_mapscript_util.c
php_mapscript_util.c: In function `_phpms_fetch_handle2':
php_mapscript_util.c:148: error: structure has no member named `properties'
php_mapscript_util.c:150: warning: dereferencing type-punned pointer will
break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_handle2':
php_mapscript_util.c:200: error: structure has no member named `properties'
php_mapscript_util.c:202: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_string':
php_mapscript_util.c:247: error: structure has no member named `properties'
php_mapscript_util.c:249: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_long':
php_mapscript_util.c:273: error: structure has no member named `properties'
php_mapscript_util.c:275: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_double':
php_mapscript_util.c:306: error: structure has no member named `properties'
php_mapscript_util.c:308: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_fetch_property_resource':
php_mapscript_util.c:332: error: structure has no member named `properties'
php_mapscript_util.c:334: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_string':
php_mapscript_util.c:368: error: structure has no member named `properties'
php_mapscript_util.c:370: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_null':
php_mapscript_util.c:396: error: structure has no member named `properties'
php_mapscript_util.c:398: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_long':
php_mapscript_util.c:425: error: structure has no member named `properties'
php_mapscript_util.c:427: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_phpms_set_property_double':
php_mapscript_util.c:454: error: structure has no member named `properties'
php_mapscript_util.c:456: warning: dereferencing type-punned pointer will
php_mapscript_util.c: In function `_php_extract_associative_array':
php_mapscript_util.c:542: warning: dereferencing type-punned pointer will
make: *** [php_mapscript_util.o] Error 1
I found another problem. If I try to compile with --with-postgis and
--with-mygis I got another error message. It seems that there are repeated
functions, is it possible to compile allowing both data sources?
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H
-DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_TIFF -DUSE_GD_PNG
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_PDF -DUSE_OGR -DUSE_GDAL
-DUSE_POSTGIS -DUSE_MYGIS -I/usr/local/include -I/usr/local/include
-I/usr/local/pgsql/include -I/usr/include/mysql -I/usr/local/include
shp2img.o -L. -lmap -lgd -L/usr/local/lib -lgd -ljpeg -lfreetype -lpng -lz
-lpdf -ltiff -ljpeg -lfreetype -lpng -lz -lproj -ljpeg -L/usr/local/lib
-lgdal -L/usr/local/pgsql/lib -lpq -L/usr/lib -lmysqlclient -lz -lcrypt
-lnsl -lm -L/usr/lib -lssl -lcrypto -lmysqlclient -L/usr/local/lib -lcurl
-lssl -lcrypto -ldl -lz -lm -lstdc++ -o shp2img
./libmap.a(mapmygis.o)(.text+0x0): In function `DATAERRORMESSAGE':
: multiple definition of `DATAERRORMESSAGE'
./libmap.a(mappostgis.o)(.text+0x1c0): first defined here
/usr/bin/ld: Warning: size of symbol `DATAERRORMESSAGE' changed from 219 in
./libmap.a(mappostgis.o) to 480 in ./libmap.a(mappostgis.o)
./libmap.a(mapmygis.o)(.text+0x9c0): In function `prep_DB':
: multiple definition of `prep_DB'
./libmap.a(mappostgis.o)(.text+0x510): first defined here
/usr/bin/ld: Warning: size of symbol `prep_DB' changed from 1623 in
./libmap.a(mappostgis.o) to 1396 in ./libmap.a(mappostgis.o)
./libmap.a(mapmygis.o)(.text+0x1130): In function `force_to_points':
: multiple definition of `force_to_points'
./libmap.a(mappostgis.o)(.text+0xee0): first defined here
/usr/bin/ld: Warning: size of symbol `force_to_points' changed from 573 in
./libmap.a(mappostgis.o) to 654 in ./libmap.a(mappostgis.o)
./libmap.a(mapmygis.o)(.text+0x13c0): In function `force_to_lines':
: multiple definition of `force_to_lines'
./libmap.a(mappostgis.o)(.text+0x1120): first defined here
/usr/bin/ld: Warning: size of symbol `force_to_lines' changed from 450 in
./libmap.a(mappostgis.o) to 536 in ./libmap.a(mappostgis.o)
./libmap.a(mapmygis.o)(.text+0x15e0): In function `force_to_polygons':
: multiple definition of `force_to_polygons'
./libmap.a(mappostgis.o)(.text+0x12f0): first defined here
/usr/bin/ld: Warning: size of symbol `force_to_polygons' changed from 276 in
./libmap.a(mappostgis.o) to 488 in ./libmap.a(mappostgis.o)
./libmap.a(mapmygis.o)(.text+0x17d0): In function `dont_force':
: multiple definition of `dont_force'
./libmap.a(mappostgis.o)(.text+0x1410): first defined here
/usr/bin/ld: Warning: size of symbol `dont_force' changed from 151 in
./libmap.a(mappostgis.o) to 250 in ./libmap.a(mappostgis.o)
./libmap.a(mapmygis.o)(.text+0x2190): In function `find_bounds':
: multiple definition of `find_bounds'
./libmap.a(mappostgis.o)(.text+0x14b0): first defined here
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
Finally, When I try to compile with ming (I've installed latest release ming
0.3beta1), when running configure I got this message:
checking if MING/Flash support requested... yes, user supplied MING directory
./configure: line 8175: -lming: command not found
And then when running make:
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_MING_FLASH
-DUSE_TIFF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_PDF
-DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -DUSE_MYGIS -I/usr/local/include
-I/usr/local/include -I/usr/local/pgsql/include -I/usr/include/mysql
-I/usr/local/include -I/usr/local mapswf.c -o mapswf.o
mapswf.c: In function `BuildButtonFromGD':
mapswf.c:444: warning: passing arg 2 of `SWFButton_addShape' from
incompatible pointer type
mapswf.c: In function `BuildEllipseButton':
mapswf.c:529: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:534: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c: In function `BuildButtonPolygon':
mapswf.c:720: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:727: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:731: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c: In function `BuildButtonLine':
mapswf.c:782: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:788: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c: In function `msImageStartLayerSWF':
mapswf.c:976: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:980: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:986: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:991: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msDrawStartShapeSWF':
mapswf.c:1062: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1070: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msDrawMarkerSymbolSWF':
mapswf.c:1274: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1293: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1320: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1358: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1372: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1411: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1434: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `DrawButtonFilledPolygon':
mapswf.c:1508: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:1514: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:1517: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c: In function `DrawButtonPolyline':
mapswf.c:1542: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c:1547: warning: passing arg 2 of `SWFButton_addShape' from
mapswf.c: In function `msDrawLineSymbolSWF':
mapswf.c:1690: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1697: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msDrawShadeSymbolSWF':
mapswf.c:1815: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1822: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1859: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:1866: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `draw_textSWF':
mapswf.c:1984: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msDrawLabelCacheSWF':
mapswf.c:2141: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msDrawWMSLayerSWF':
mapswf.c:2534: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msDrawRasterLayerSWF':
mapswf.c:2588: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c: In function `msSaveImageSWF':
mapswf.c:2626: error: too few arguments to function `SWFMovie_save'
mapswf.c:2644: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2648: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2652: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2657: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2665: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2670: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2675: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2682: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2760: error: too few arguments to function `SWFMovie_save'
mapswf.c:2772: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
mapswf.c:2779: error: too few arguments to function `SWFMovie_save'
mapswf.c: In function `msDrawVectorLayerAsRasterSWF':
mapswf.c:2898: warning: passing arg 2 of `SWFMovie_add' from incompatible
pointer type
make: *** [mapswf.o] Error 1
If anyone can help me...
Thank you in advance!
Regards. Juan.
http://www.merlos.biz
