[Mapserver-users] help! newbie's question about displaying the shape file.
shiming
sli1 at uni-forst.gwdg.de
Mon May 31 12:09:36 EDT 2004
Hello, everyone,
Recently I installed the MapServer program, and I can run the demo itasca.
I can display shape file from ArcView example in MapServer , but when I
run with my shape file, there are no image in the image area, just white
space, but the legend and the reference are showed.
My shape file can be displayed in the ArcView environment.
Is there some requirement about the shape file?
The unit of extent is geographic.
What's wrong with me? Can you point the error for me?
Any ideas will be appreciated.
Thanks in advance.
I use MapServer version 4.0.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
SuSE linux 8.2 and apache2, the directory of
/usr/local/apache2/htdocs/tmp can be written.
The following is .map file
MAP
NAME XX
#EXTENT 110.991 33.0895 111.83 33.8029
EXTENT -180 0 180 90
SIZE 400 300
SHAPEPATH "data"
FONTSET "font/fonts.list"
IMAGETYPE PNG
PROJECTION
"proj=latlong"
END
UNITS dd
DEBUG ON
WEB
TEMPLATE xx_demo.html
IMAGEPATH "/usr/local/apache2/htdocs/tmp/"
IMAGEURL "/tmp/"
LOG /tmp/log.txt
END
LEGEND
STATUS ON
LABEL
TYPE TRUETYPE
FONT arial
COLOR 0 0 0
SIZE 12
ANTIALIAS TRUE
END
END
REFERENCE
STATUS ON
IMAGE "data/reference.png"
SIZE 170 138
# EXTENT 110.991 33.0895 111.83 33.8029
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME dxregion
TYPE polygon #POLYGON
STATUS DEFAULT # OFF
DATA dxregion #dxregion
# Starts with the keyword CLASS and terminates with the keyword END.
CLASS # and each layer must have at least one class.
NAME dxregion
EXPRESSION /./ # '50'
OUTLINECOLOR 128 128 200
# COLOR 225 225 185
END
DEBUG ON
END
END # end of map file
