mapserv install problem
Terry Brown
tbrown at NRRI.UMN.EDU
Mon Nov 1 18:59:20 EST 2004
On Mon, 1 Nov 2004, Ethan Alpert wrote:
> Giving your layer a name will do the trick.
That's it, thank you!
> NAME "mypoint"
> I think mode=browse expects more information.
> Also I make my IMAGEURL relative to the top of my document root.
> -e
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Terry Brown
> Sent: Monday, November 01, 2004 1:03 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] mapserv install problem
> Trying to get a minimal demo running. Map file and template below, but
> short story is that when going to
> http://myhost.net/cgi-bin/mapserv?map=/home/ms/local/img/test0.map
> The image is being generated in IMAGEPATH and is viewable via IMAGEURL
> if entered directly, BUT whatever the first [square-bracket] expression
> in the template is, output (view source) ends on the proceeding line.
> Thanks for any clues.
> MapServer version 4.2.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
> Linux Mandrage 10.0 Apache
> MAP
> DEBUG on
> SIZE 600 400
> EXTENT 0 0 1000 1000
> WEB
> IMAGEPATH "/home/ms/local/img/"
> IMAGEURL "http://myhost.net/mapimg/"
> TEMPLATE "/home/ms/local/tmpl/test0.html"
> END
> LAYER
> TYPE point
> CLASS
> COLOR 0 0 0
> END
> FEATURE
> POINTS
> 50 500 500 100
> END
> END
> END
> END
> with /home/ms/local/tmpl/test0.html
> (replacing angle brackets with parentheses for email)
> (html)
> (head)
> (title)test0(/title)
> (/head)
> (img src="[img]" border="0" width="300" height="400")
> (/body)
> (/html)
> Terry Brown Natural Resources Research Institute
> Research Associate 5013 Miller Trunk Highway
> tbrown at nrri.umn.edu University of Minnesota, Duluth
> Ph. 218 720 4345 Duluth, Minnesota 55811
> Fax 218 720 4328 http://beaver.nrri.umn.edu/~tbrown/
