Slight rendering problem with 4.4-beta1 ...
Steve Lime
steve.lime at DNR.STATE.MN.US
Wed Nov 3 13:01:08 EST 2004
> Could it be related to the labelling cache? In what order are labels
drawn?
> If from top-left to bottom-right, then it would seem that it's alway
sthe
> "last" label that does this ... I'll try more maps to see if I detect
a
> pattern (It's a bit of work because I have to convert the mapfile
from
> 3.6.6).
J.F.: Labeling is done in:
- reverse order of how features appear in the dataset (last into the
cache is first drawn)
- reverse layer order (last layer is labeled first)
If you make up a mapfile with just the layer showing the problem does
the problem
persist?
Steve
