thread safe implementations
Dan Barron
dbarron at DSWLLC.COM
Thu Nov 4 10:12:12 EST 2004
Umberto,
I'm not going to try to recreate the functionality of the cgi - I'm not
fully sure yet what absolute path I will take - I really have not done much
threaded java code. I've looked at the java mapscript - and your map
server wiki entries for compiling java mapscript - I'm not convinced I have
a good compile yet (platform is Fedora Core 2). Is the java mapscript
viable at this point? I have read posts from earlier this year saying it
looked abandoned?
I would really like to get to an all java solution if possible - I
currently use a combination of java/php (java opens a connection to a php
script then parses the returned data) - not the best but it seems to work
fine under light loads.
I'd be interested to hear more about what you are up to - it sounds
interesting. I would really like to just build a threaded front end (maybe
a thread pool?) to the map server functionality via java mapscript and
nothing more.
Thanks,
Dan
At 11:51 PM 11/3/2004, unicoletti at prometeo.it wrote:
>Dan,
>if by creating a java implementation you mean writing a web app to deliver the
>same (or subset) of the functionality the cgi does, then I am writing one.
>I think I am one of the few java mapscript users around :-)
>Regards,
>umberto
>Quoting Sean Gillies <sgillies at FRII.COM>:
> > Dan,
> > It's not clear to me what you mean by creating a java implementation
> > on your own. Implementation of what? Do you mean a programming API
> > like the php mapscript module?
> > If this is what you mean, you should look at the Java stuff that
> > you can generate using SWIG. In mapserver versions 4.2.4+ and in
> > the 4.4.0 beta1 there is a Java makefile under mapserver/mapscript/java.
> > It seems to work, but as I've said -- I'm not a Java user and so am
> > not beating on the Java mapscript module heavily enough or often
> > enough to say anything about its readiness.
> > Sean
> > On Nov 3, 2004, at 10:37 AM, Dan Barron wrote:
> > > Hmmm - I was really hoping someone had done (or attempted) a java
> > > implementation - I'm not versed in Zope or Python. Well, I guess I
> > > will
> > > attempt to create a java implementation on my own.
> > > Thanks Sean.
> > > Dan
> > > At 01:10 PM 11/2/2004, Sean Gillies wrote:
> > >> On Nov 2, 2004, at 10:47 AM, Dan Barron wrote:
> > >>> Hello,
> > >>> Just curious what the current consensus and recommendations are for
> > >>> creating a thread safe front end or wrapper for mapserver in either
> > >>> php or
> > >>> java? I'm assuming that mapserver is still not thread safe - that
> > >>> correct?
> > >>> Thanks!
> > >>> Dan
> > >> Dan,
> > >> I caught and fixed three sources of potential threading problems
> > >> before
> > >> the 4.2.4 release and these fixes will also be in 4.4.0. I think
> > >> we're
> > >> close to thread safety, but it's hard to say without more testing. As
> > >> far as I know, my ZMapServer (Zope + Python mapscript) software is the
> > >> only thing out there that is using MapServer in a multi-threaded
> > >> environment. It works, but is not a complete proof of thread safety.
> > >> There remains much work to be done to in improving MapServer's
> > >> threaded performance. The single lexer for parsing mapfiles and
> > >> class expressions is a bottleneck that will be addressed in the
> > >> future.
> > >> cheers,
> > >> Sean
> > >> Sean Gillies
> > >> sgillies at frii dot com
> > >> http://users.frii.com/sgillies
