WFS map file
N Zhou
zhou_naijun at HOTMAIL.COM
Fri Nov 5 12:41:32 EST 2004
I'm new to the WFS. I have a working WMS map file, and I followed the HOW To
instruction to modify the WMS map file to WFS. However, only the layer name
can be showed as WFS not the real layer map. Is this because of map
projection: the data are in a projection currently not supported in EPSG? Or
I have errors in the map file?
Thank you very much!
My map file is:
Map
NAME "MyServices"
STATUS ON
EXTENT 177185 124886 891620 939320
SIZE 400 400
UNITS METERS
# Start of web interface definition
WEB
MINSCALE 1
MAXSCALE 10000000
METADATA
"wfs_title" "DNRServices"
"wfs_srs" "EPSG:90000"
"wfs_onlineresource"
"http://myhost/cgi-bin/mapserv?map=thismapfile.map"
END
END
PROJECTION
"init=epsg:90000"
END
# Start of layer definitions
LAYER
NAME "water"
STATUS ON
DATA "hydppoly"
TYPE POLYGON
CLASSITEM 'HYDNW92M_'
MINSCALE 400000
PROJECTION
"init=epsg:90000"
END
DUMP TRUE
METADATA
"wfs_title" "Open Water"
END
CLASS
EXPRESSION /./
STYLE
COLOR -1 -1 -1
OUTLINECOLOR 0 0 255
SIZE 1
SYMBOL 0
END
END
END
END
N. Zhou
