Mapserv.exe {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sat Nov 6 06:29:26 EST 2004
Try to run mapserv.exe from a command (dos) window with the -v switch
mapserv.exe -v
it is a way to test if it's working. You will get somethig like this:
MapServer version 4.3 OUTPUT=GIF OUTPUT=PNG ....
To test from your browser you must give a query string in the url
http://localhost/cgi-bin/mapserv.exe?map=path_to_your_map_file&mode=map
but you must create your map file before.
You had better to start with Itasca demo
Bye
Zoltan
On Sat, 6 Nov 2004, nasir maan wrote:
> Hi,
> I installed mapserver but when I tried to test it by putting
> it gives me following error in error log file;
> [error] [client 127.0.0.1] Premature end of script headers: mapserv.exe
> Can anybody tell me where is problem?
> Regards,
> Mahmood, Nasir
> J.-G.-NATHUSIUS-RING 1/408
> 39106, Magdeburg
> Germany.
> Phone: +49-391-2428300 (Home)
> +49-176-24211916 (Mobile)
> ________________________________________________________________________________
> Express yourself instantly with MSN Messenger! MSN Messenger Download
> today it's FREE!
