RES: [UMN_MAPSERVER-USERS] layer group(s)?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Nov 8 16:50:58 EST 2004
There was a resent post here or on the dev list regarding the multiple
NAME or GROUP tags that only the last is remembered and on the current
beta it will now throw an error if you have multiple name tags.
-Steve
Murilo Lacerda Yoshida wrote:
> I tried here to do that... Apparently if you set two groups on one
> layer, the last group assigned is the one that counts... The other one
> is forgotten ... I'll change the order of the groups here and see what
> happens.
> The strange thing is that mapserver doesn't show an error for that.
> Thanks Eric,
> Murilo
> -----Mensagem original-----
> De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
> nome de Eric Bridger
> Enviada em: segunda-feira, 8 de novembro de 2004 14:45
> Para: MAPSERVER-USERS at LISTS.UMN.EDU
> Assunto: Re: [UMN_MAPSERVER-USERS] layer group(s)?
> I don't think that is possible, but it is easy enough to create two
> identical layers but assign one to group one and the second to group
> two.
> Eric
> On Mon, 2004-11-08 at 13:19, Murilo Lacerda Yoshida wrote:
>> Hi all,
>> A layer can have more than one group?
>> I wanted to set two groups on a layer, because it belongs to two
>>groups of layers ... is that possible?
>> Thanks,
>> Murilo
