GDAL 1.2.4 Released
Frank Warmerdam
warmerdam at POBOX.COM
Mon Nov 8 17:17:31 EST 2004
Folks,
GDAL 1.2.4 has been officially released.
http://www.gdal.org/dl/gdal-1.2.4.tar.gz
http://www.gdal.org/dl/gdal124.zip
The NEWS is below, but I wanted to highlight a copy things:
1) There were some very serious bugs in the OGR VRT driver which
resulted in crashes in some common scenarios where it is used
as a front to an ODBC database in MapServer. Please update as
soon as possible if you are using OGR VRT datasources.
2) Libtiff is under active revision lately, and I believe there may
have been some signficant bugs in 1.2.3 with building overviews.
Consider upgrading to 1.2.4 if you might be doing this (even for
non-GeoTIFF formats since the overviews are stored as TIFFs).
Enjoy!
GDAL 1.2.4 - Overview of Changes
gdalwarp:
- Fixed some issues with only partially transformable regions.
- Added Alpha mask generation support (-dstalpha switch).
HFA/Imagine Driver:
- bug fix in histogram handling.
- improved support for large colormaps.
Envi Driver:
- Capture category names and colormaps when reading.
SAR CEOS Driver:
- Added support for PALSAR/ALOS Polarmetric Datasets.
RadarSat 2 Driver:
- New. Reads RadarSat 2 Polarmetric datasets with a "product.xml" and
imagery in TIFF files.
OGDI Driver:
- Important bug fix for downsampled access.
GeoTIFF Driver:
- Lots of libtiff upgrades, including some quite serious bug fixes.
- Added better support for 16bit colormaps.
- Write projection information even if we don't have a geotransform or GCPs.
- Improved alpha support.
- Generate graceful error message for BigTIFF files.
DODS Driver:
- Almost completely reimplemented. Uses chunk-by-chunk access. Supports
reading several bands from seperate objects. Some new limitations too.
NetCDF Driver:
- Seperated out a GMT NetCDF driver and a more generic but partially broken
NetCDF driver (Radim).
JP2KAK Driver:
- Added alpha support, including greyscale+alpha.
AirSAR Driver:
- New, reads AirSAR Polarmetric Radar format.
OGR 1.2.4 - Overview of Changes
epsg_tr.py:
- Added escaping rules when generating PostGIS output.
tigerpoly.py:
- Discard dangles and degenerate rings.
VRT Driver:
- Fixed serious error in handling cleanup of VRT datasources, was often
causing a crash.
SQLLite Driver:
- Fixed substantial memory leaks.
MySQL Driver:
- New readonly non-spatial MySQL driver implemented.
MITAB Driver:
- Updated from upstream, several fixes.
TIGER/Line Driver:
- Fixed serious bug with handling "full" records at end of .RT2 file.
OCI/Oracle Driver:
- Added OCI_FID environment support to control FID selection.
OGRGeometry:
- Added Centroid() implementation (from GEOS?)
and watch the world go round - Rush | Geospatial Programmer for Rent
