tiff is shown in grayscale
Frank Warmerdam
warmerdam at POBOX.COM
Tue Nov 9 12:21:59 EST 2004
Carsten Keßler wrote:
> Hi,
> I'm using a number of shapes and a tiff to generate the ouput map, with
> MapServer 4.2.0 on Windows. The original tiff file is in RGB mode, with
> 8 bit per channel. The shapefiles are drawn correctly (in color), but
> the tiff is only in grayscale on the output maps. This is the part of
> the map file which defines the tiff layer:
> LAYER
> NAME basemap
> TYPE RASTER
> DATA rectifyos.tif
> CLASS
> NAME 'Basemap'
> END
> METADATA
> WMS_TITLE "Basemap"
> WMS_ABSTRACT "Basemap ..."
> WMS_SRS "EPSG:31467"
> END
> END
Carsten,
The problem is that when you declare a CLASS on the raster layer it forces
the layer to be rendered in classified mode. This uses only one band and
defaults to greyscale.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
