loading mapscript in java error
Umberto Nicoletti unicoletti at PROMETEO.IT
Wed Nov 10 02:56:36 EST 2004
On Tue, 2004-11-09 at 19:53, dbarron wrote:
> Sean,
> Using the patched mapgml.c and recompiling seems to have helped fix the problems I was seeing. It appears to be working right now and I just have some environment issues to work out.
> For example if I do not specify the mapscript.jar on the java command line then the java command will only look in <java_home>/jre/lib/ext for it and I get an exception:
>  # java -verbose MapScriptTest
>   loading mapscript library...
>   mapscript library LOADED...
>   [Loaded edu.umn.gis.mapscript.mapObj from file:/usr/local/jdk1.5.0/jre/lib/ext/mapscript.jar]
at this point java is loading mapscript classes from
Could it be that you have and old (I presume) version of mapscript
around?
However the UnsatisfiedLinkError means that the mapscript.jar refers to
, well, a Linker error :-) (the linker cannot locate functions in the
shared library).
Make triple sure you do not have old mapscript.jar or .so around. Also
check your environ.
>   [Loaded edu.umn.gis.mapscript.mapscriptJNI from file:/usr/local/jdk1.5.0/jre/lib/ext/mapscript.jar]
>   [Loaded java.lang.UnsatisfiedLinkError from shared objects file]
>   Exception in thread "main" java.lang.UnsatisfiedLinkError: new_mapObj
>         at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
>         at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:334)
>         at MapScriptTest.main(MapScriptTest.java:13)
>   [Loaded java.lang.Shutdown from shared objects file]
>   [Loaded java.lang.Shutdown$Lock from shared objects file]
> Then, if I export the CLASSPATH again and specify the jar file on the command line then I move beyond that error to an actual mapserver map file issue:
>   #export CLASSPATH
>   #java -verbose -classpath $CLASSPATH:/usr/local/lib/java/mapscript.jar MapScriptTest
>   [Loaded edu.umn.gis.mapscript.mapObj from file:/usr/local/lib/java/mapscript.jar]
>   [Loaded edu.umn.gis.mapscript.mapscriptJNI from file:/usr/local/lib/java/mapscript.jar]
>   [Loaded java.lang.UnknownError from /usr/local/jdk1.5.0/jre/lib/rt.jar]
>   Exception in thread "main" java.lang.UnknownError: Given map extent is invalid.
> This tells me it is working - would you and Umberto agree?  I'll bang on it more today and see where it leads me as well.
Yes, it is working. Correct extents in your map.
Regards,
Umberto
> Thanks for all your efforts!
> Dan
