wcs issues on getting data
Nuno GIL
nunoragil at YAHOO.COM
Wed Nov 10 13:53:02 EST 2004
Unfortunately, didn't help :-(
Thanks anyway Frank.
Best regards,
N
--- Frank Warmerdam <warmerdam at POBOX.COM> wrote:
> Nuno GIL wrote:
> >Dear listers,
> >I've installed mapserver in order to use its wcs
> >capabilities.
> >The GetCapabilities request works fine, the problem
> is
> >when I try to use the GetCoverage request. Actually
> I
> >don't receive any error message, but the received
> file
> >is empty.
> >I'm querying the server with this request:
>http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?REQUEST=GetCoverage&COVERAGE=l5&SERVICE=WCS&map=/ge/data/iceds/alpha/umms/wcs_land3.map&BBOX=48.5,-21.5,48.7,-21.3&FORMAT=GEOTIFF_RGB&CRS=EPSG:4326&RESX=0.00027778&RESY=0.00027778
> >Just to try and sort out the problem, I reduced the
> >data being served to only a simple image with one
> >channel (no tiles), no results as well...
> Nuno,
> I notice you have no coordinate system defined for
> your image as a
> PROJECTION
> block. I would encourage you to add a block like
> this in your layer:
> PROJECTION
> "+init=epsg:4326"
> END
> If it makes things work, please update the WCS wiki
> docs to mention this
> requirement.
> Best regards,
> I set the clouds in motion - turn up | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
