wcs issues on getting data
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Wed Nov 10 16:24:59 EST 2004
On Wed, 2004-11-10 at 10:31 -0800, Nuno GIL wrote:
> Dear listers,
> I've installed mapserver in order to use its wcs
> capabilities.
> The GetCapabilities request works fine, the problem is
> when I try to use the GetCoverage request. Actually I
> don't receive any error message, but the received file
> is empty.
> I'm querying the server with this request:
> http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?REQUEST=GetCoverage&COVERAGE=l5&SERVICE=WCS&map=/ge/data/iceds/alpha/umms/wcs_land3.map&BBOX=48.5,-21.5,48.7,-21.3&FORMAT=GEOTIFF_RGB&CRS=EPSG:4326&RESX=0.00027778&RESY=0.00027778
> Does anyone understands what is going wrong? Any help
> would be much appreciated.
Nuno,
1. Are you able to see the image when you run a regular MapServer CGI
request (i.e.
http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?map=/ge/data/iceds/alpha/umms/wcs_land3.map&layer=LC5&mode=map)?
2. Is your image 16- or 8-bit? If 8-bit, perhaps you should replace
IMAGEMODE INT16 with IMAGEMODE PC256 in OUTPUTFORMAT (also replace the
NAME accordingly).
3. What Frank said in another post.
Cheers!
Perry
Pericles S. Nacionales <nacional at cbs.umn.edu>
