Color ramping
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Nov 10 18:01:20 EST 2004
I don't think there is other than assign a range of ranges to a class
via an expression. For some projects, I have add a COLOR attribute, like
number 1-10 then made a layer with ten classes in it and did the color
assignment that way.
It would be nice to have something like:
COLOR_RAMP
COLOR_ATTRIBUTE <column_name>
MIN_VALUE <num1>
MAX_VALUE <num2>
MIN_COLOR R G B
MAX_COLOR R G B
COLOR_STEP n
OFF_COLOR R G B
END
Where the value from the column would be interpolated between min and
max value and then assign a color value appropriately between min and
max color. COLOR_STEP would define discreet steps in the color ramp. and
any value outside min and max value would be assign OFF_COLOR
But alas we don't have anything like this :(
-Steve W.
Bob Basques wrote:
> All,
> I have the Contour layer displaying fairly quickly now. The next order
> of business is to display it with a color-ramp.
> Are there any programtric ways of accomplishing this with the
> attributes. I have elevation attribute on each line that I use for
> labelling, I would like to change the colors (color-ramp) via this
> attribute.
> Aside from assigning every individual elevation (or groups of
> elevations) a color, is there a MAPFILE (or Trick) config that could
> make this happen?
> Thanks
> bobb
