OGR bug?
Ivano Picco
ivano.picco at AQUPI.TK
Thu Nov 11 10:35:13 EST 2004
Thank you another time,
as you can see my answer was really stupid. :)
I'm gettin' confused because configure didn't give me an error using
--with-oci_fid. Sorry!
I try the daily snapshot, now it works!
thanks for your job,
Ivano Picco
On Thu, 11 Nov 2004 09:28:24 -0500, Frank Warmerdam <warmerdam at POBOX.COM> wrote:
>Ivano Picco wrote:
>> Maybe it's stupid or maybe I found the way to specify another primary key. I
>> have to use the pair --with-oci_fid when i run configure as it is reported
>> in the source code, isn't it?
>> Can you add this information in documentation or in the configure help so it
>> can be read to the other people needed it?
>Ivano,
>OCI_FID is a configuration variable for OGR. That means you can set it as
>an environment variable or define it in a CONFIG directive in your mapfile.
>It isn't a configure time option.
>I will add documentation about it to OGR driver docs though it was primarily
>intended as a temporary hack till I can figure out how to identify the primary
>key using OCI (hints welcome).
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
